Just when I thought I seen everything!
1370rod
PostPosted: Wed Dec 06, 2017 4:20 pm    Post subject: Just when I thought I seen everything! Reply to specific post Reply with quote
A good customer brought his 870 over because of powershift issues. He can not understand why his RPS valve has spools sticking again. Well at least he did not throw the bypass valves away, but they will do no good if he installs them in the top of the filters again. Geez, I hate to tell him after 30 years of owning this tractor he screwed up, but I guess I have to. Rod.
Adirondack case guy
PostPosted: Wed Dec 06, 2017 4:38 pm    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
I guess the old saying still fits. "You can lead them to water, but you can't make them drink"
Loren
JD Seller
PostPosted: Wed Dec 06, 2017 6:03 pm    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
Well I am not a Case guy. So would you explain what he did wrong in a little more detail for the Non Case expert group. LOL
I am guessing that these valves have to be switched when you change the filters and he put them in the wrong end????
Case Nutty 1660
PostPosted: Wed Dec 06, 2017 6:52 pm    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
You have it, the link should take you to the breakdown page
cnt
filter link
Ande
PostPosted: Wed Dec 06, 2017 6:59 pm    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
Well Rod, better you telling him as a old friend, then him taking it somewhere, they tear it all down and give him a 8k bill, he will be thankful for good friends like you
olgentdc
PostPosted: Wed Dec 06, 2017 7:02 pm    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
they aint gonna get much oil neither ,..
1370rod
PostPosted: Thu Dec 07, 2017 5:37 am    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
As Tom's pic shows the valves go in the bottom of the filters. When installed correctly they force the oil to pass through the filters. If the filters become plugged or oil to thick that in can not pass through the filters, the valves open allowing some oil to by-bass to prevent oil starvation problem else where. That is where the name by-pass relief valve came from. Rod.
2510Paul
PostPosted: Thu Dec 07, 2017 8:21 am    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
So is that item 3 in the picture? Paul, ya, not a case guy either.
Case Nutty 1660
PostPosted: Thu Dec 07, 2017 8:38 am    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
Yes Paul #3 is the relief valve Rod is speaking of
cnt
Brokengun
PostPosted: Thu Dec 07, 2017 9:46 am    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
May be he had some help changing filters and didnt know what had happened.
mEl
PostPosted: Fri Dec 08, 2017 12:38 pm    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
Were the springs on the bottom then?
1370rod
PostPosted: Sat Dec 09, 2017 6:35 am    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
Mel, yes the spring are installed at the bottom of the filters, sort of difficult to see in the pic.
Rod.
mEl
PostPosted: Sat Dec 09, 2017 7:16 pm    Post subject: Re: Just when I thought I seen everything! Reply to specific post Reply with quote
[quote="CVPost-1370rod"](quoted from post at 10:35:01 12/09/17) Mel, yes the spring are installed at the bottom of the filters, sort of difficult to see in the pic.
Rod.[/quote
Its a wonder the cans didn't split with the reliefs having the top outlet passage blocked
