Need to figure out what yeat this MHF Tractor is
Goto page 1, 2  Next
FarmboyJohn
PostPosted: Wed Dec 06, 2017 5:29 pm    Post subject: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
the clutch works I just got it running after it has sat for 8 Months, This is My uncles Tractor He has asked me to work on it first stage of the clutch works but not for the PTO water is in the mid section and rear im going into this blind no book because i do not know the year Z134 621 373??? stamp on motor MHF 180-402-MI on gear box. thanks
Question Question
BIG1RED9
PostPosted: Wed Dec 06, 2017 6:10 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
From what I understand, you will need the serial number. No idea where it would be located, but you could do a search of the model to find out where they put the serial number. With that you can determine its year online or then post it and ask to help figure it out.
Don
miner09
PostPosted: Wed Dec 06, 2017 6:36 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
Look under steering wheel on left side dash is the serial number. Change oil-two drain
plugs left side and replace transmission lever rubber boots. 8 gallons oil.
FarmboyJohn
PostPosted: Wed Dec 06, 2017 6:47 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
thats the 180-402
FarmboyJohn
PostPosted: Wed Dec 06, 2017 6:50 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
Nothing on the steering on either side i posted picturs of all the possible #s i could find
BIG1RED9
PostPosted: Wed Dec 06, 2017 6:58 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
To me it looks like the model on the hood area shows 595. Your looking for a tag / plate.
ptfarmer
PostPosted: Wed Dec 06, 2017 11:56 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
Some pictures of the tractor would help a lot, the more the better.
SimonRidout
PostPosted: Thu Dec 07, 2017 8:31 am    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
I have a MF 575. MF produce a workshop manual, which covers the 500 range, When needed, it has different paragraphs for different models. Obviously, living in England, I do not know if it available in the USA.
FarmboyJohn
PostPosted: Thu Dec 07, 2017 8:55 am    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
[/img]
ptfarmer
PostPosted: Thu Dec 07, 2017 11:16 am    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
I'd say its a Ferguson TO35, the MF35 is pretty much the exact same tractor. Someone maybe able to determine a year model using the tag on the engine provided the engine hadn't been swapped out with a different one. Without the tag on the tractor it's hard to say what year it is. The casting numbers are rarely, if at all are not the same as a part number.
miner09
PostPosted: Thu Dec 07, 2017 12:19 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
Picture is a 1955 TO 35. It's a single stage clutch. Clutch pedal is different from
other 35's is one way to tell.
miner09
PostPosted: Thu Dec 07, 2017 12:21 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
Painted like a Ford. It should be green chassis and gray fenders.
Jim in rush co
PostPosted: Fri Dec 08, 2017 10:35 am    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
With the 2 buttons on hood and MHF on castings would be first half of 1956 TO35! Around May or June, and probably has 12 bolts on axel flange instead of 8. Jim
Jim in rush co
PostPosted: Fri Dec 08, 2017 10:41 am    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
And would also be 2 stage clutch.
FarmboyJohn
PostPosted: Sun Dec 10, 2017 3:20 pm    Post subject: Re: Need to figure out what yeat this MHF Tractor is Reply to specific post Reply with quote
[quote="CVPost-Jim in rush co"](reply to post at 11:41:31 12/08/17) [/quote
Where the dry cavity is,. I have black oil. Loosened the inspection plate to let drip. Behind that is the shifters hi low transmission gearing I have to drain that. B/c water Same with the rear axle for the PTO.it booth white. I'm working on a International 300 Farmall close to the same year. Waiting to get the starter back. So I can move the Massey so I can split the tractor and see really what I am looking at. I was told that the seal was bad. The Massey is still working. Just the PTO not properly. The More information I can get the better. Ty
Goto page 1, 2  Next
Page 1 of 2
