Frozen water lines
Goto page 1, 2  Next
SVcummins
PostPosted: Thu Dec 07, 2017 11:00 am    Post subject: Frozen water lines Reply to specific post Reply with quote
I think I have finally figured out a way to water my stock without having to roll up 350 feet of garden hose every time I made an adapter that I can hook up my diesel air compressor to blow the hose out
David G
PostPosted: Thu Dec 07, 2017 11:20 am    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
I made a similar one for my power washer
SVcummins
PostPosted: Thu Dec 07, 2017 11:27 am    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
I left it hooked up for about 5 minutes and made sure all the water was out I think it?s going to work
grizz02
PostPosted: Thu Dec 07, 2017 11:30 am    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
made one years ago to blow out underground sprinklers throw small compressor in loader bucket and run around from hydrant to hydrant when air gets low just run back to shop plug it in till its full
gene bender
PostPosted: Thu Dec 07, 2017 12:06 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
That will not blow all the water out. The air will move water so the air can move thru then the remaining water will flow back to a low place and freeze. So after blowing the air thru pick up the hose as you move along till you get to the end and the remaining water will run out the end. BTDT
Kansas4010
PostPosted: Thu Dec 07, 2017 12:08 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
Should work. That's what they use to blow out rv's and camper trailers.
kcm.MN
PostPosted: Thu Dec 07, 2017 12:55 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
I don't remember how many feet of water line you'll have strung out there, but gene bender has a good point. Any moisture that remains on the hose lining will find its way to a low point and, if enough water builds up at any one point, you will be unable to water again until it thaws.
Maybe you could blow the hose out to start with, then connect the nearest end to a wet/dry vac and let that suck any remaining water for 15 minutes or so? ...Or maybe come back after 15 or 30 minutes and blow it out again, once any remaining water has puddled??
mj
PostPosted: Thu Dec 07, 2017 1:14 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
What Gene said.
paul
PostPosted: Thu Dec 07, 2017 1:21 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
Kansas, I will have to look for one of those! Never seen one.
I deal with cattle and gravity feed cisterns and waterers and so forget, and need to blow out pipe and hoses a lot. That is a lot simpler that the stuff I screw together to adapt......
Paul
Kansas4010
PostPosted: Thu Dec 07, 2017 1:35 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
That one is from Amazon. Just type in garden hose air adapter. I've seen them at local Menards as well.
paul
PostPosted: Thu Dec 07, 2017 1:41 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
Cool, my menards expanded a year ago, and likely has it - or will over summer - now. They started out a small/ medium size building but had enough traffic to move all the lumber and garden to new quarters and turn those areas into more retail stuff. I've noticed a lot notpre of that type stuff available now.
Paul
onefarmer
PostPosted: Thu Dec 07, 2017 2:21 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
Can you run the hose up over a roof or build a bridge of some kind to run it up over? 350ft is a long ways but I put a pvc line from one end of my 100ft shed to the other up to the peak and back down. Lines drains out each end via gravity
ohiojim
PostPosted: Thu Dec 07, 2017 2:28 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
I don't think you'll ever get all the water out of 350 feet of hose to keep it from freezing. I hope it works for you, keep us up dated.
SVcummins
PostPosted: Thu Dec 07, 2017 2:46 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
I don?t know either I left it on until no more water came out I guess we?ll see
SVcummins
PostPosted: Thu Dec 07, 2017 2:51 pm    Post subject: Re: Frozen water lines Reply to specific post Reply with quote
I may be able to I?m not sure if it doesn?t work I will be rolling up hose again I guess
Goto page 1, 2  Next
Page 1 of 2
