Pre-1930 John Deere Dain Side Delivery Hay Rake
HillsideFarm1932
PostPosted: Thu Dec 07, 2017 2:23 pm    Post subject: Pre-1930 John Deere Dain Side Delivery Hay Rake Reply to specific post Reply with quote
Restoring a 1928-29 three bar John Deere Dain
Side Delivery Hay Rake that belonged to my
grandpa and am in need of a few "smalls" in the
parts department.
This is the one that had wood clamped to the
tinebars and the tine holding ends went through the wood.
Pretty sure all the pre1930 JD Dain units were like
this.
I need some of the cast clamps that held the wood
in place on the tinebar(both the top ones and the
ones on bottom that went between the tinebar and
wood)
I also need some tines.
Need at least 6 of each but will purchase more if
priced fairly since I'd like some spares. I plan to use
it when finished but only on 2 acres of timothy hay.
I also need all 3 lever latch adjusting handles mine are missing.
Has been out of service for about 60 years!
Send pics if possible along with price and quantity available to my email below. Thank You! Kevin
Email: KvMoc@aol.com
Leroy
PostPosted: Thu Dec 07, 2017 4:57 pm    Post subject: Re: Pre-1930 John Deere Dain Side Delivery Hay Rake Reply to specific post Reply with quote
I have one of them but no extra parts and don't know of any place you can get them. A lot of rakes the Amish can get parts for but not them. For the pieces to hold the wood bar on just uses fender washers of 1.5" outside diameter with standard washer against the fender washer that will be smaller outside diameter but will strngthed the fender washer to where it will work. As far as teeth I have no idea what would work.
Graham of New Zealand
PostPosted: Thu Dec 07, 2017 10:21 pm    Post subject: Re: Pre-1930 John Deere Dain Side Delivery Hay Rake Reply to specific post Reply with quote
I'm sure a spring maker would make tines in a jiffy especially if you have one to take as a sample. Actually if you can get your hands on some suitable wire spring. you could make up a former and make a few yourself. Might not be factory quality but do a bit and look ok. Might even be able to modify some existing tines. Always worth a try, I say.
DeltaRed
PostPosted: Fri Dec 08, 2017 7:43 am    Post subject: Re: Pre-1930 John Deere Dain Side Delivery Hay Rake Reply to specific post Reply with quote
I'm with Graham. On a machine that old,you may have to resort to making some parts and modifying others to make it work. May not be a 'factory perfect' show piece,but can be made to be quite useable.Add a little paint and it will still look sharp.
Farmallb
PostPosted: Fri Dec 08, 2017 8:13 am    Post subject: Re: Pre-1930 John Deere Dain Side Delivery Hay Rake Reply to specific post Reply with quote
I had a 3 bar JD, not that old, as a kid, and I never saw the difference in the quality of the windrow or any more leavings than with my dads 4 bar rake I have now.
Try MacNairs in Penn. IF you have any teeth left on it as a guide, there are parts catalogs that have numerous sizes and shapes of teeth and you might find just what you need.
I bought teeth for my rake from a supplier. They were too long, and hit the center reel. I had to cut them down, and put a slight bend on the tip end. Havnt used it yet tho so I don't know how it will work, but I suspect just fine.
730virgil
PostPosted: Fri Dec 08, 2017 8:23 am    Post subject: Re: Pre-1930 John Deere Dain Side Delivery Hay Rake Reply to specific post Reply with quote
try ag supply in north carolina
doa44green
PostPosted: Fri Dec 08, 2017 4:50 pm    Post subject: Re: Pre-1930 John Deere Dain Side Delivery Hay Rake Reply to specific post Reply with quote
I think I may have one in the woods. I'll try to send you some photos in a few days.
Don
Leroy
PostPosted: Sat Dec 09, 2017 7:52 am    Post subject: Re: Pre-1930 John Deere Dain Side Delivery Hay Rake Reply to specific post Reply with quote
No use even trying, they will not have them. Remember that rake is 90 years old and very few were ever sold as the dump rake was what was still selling and it would be easier to find a new tooth for a dump rake now than that Dain that was built as far back as at least 1922. His only chance to get teeth would be to find a place that makes springs but then the cost even if they could make them would be over a hundred dollars a piece. The closest tooth I have ever seen that might be able to be mounted is from a David Bradley and those are not avaible either. Teeth for a Moline made in the 50's are not avaible either. I have access to local dealers that have the catalogs of every rake tooth made that is avaible. I have modified things to put McCormick teeth on a Moline rake and For Case a New Idea tooth can be used but a Case tooth will not work on a New Idea. And some rake teeth are hardened steel and others are not and can be straightened, some will just break. So to get a tooth that looks half ways correct for that rake he could take 3/16" steel rod and bend it to shape and it might (?) last for a short while but it might bend as soon as tried. I have rebuilt dozens of steel wheel rakes over the last few years to go back in to fields to go to work. Have a New Idea setting here just finished waiting to be delievered and a second waiting along with a John Deere. Did you know a real from a Massey Harris can be put in a McCormick. A 594Ly Deere can be converted to a high steel wheel model? And I have put the New Idea 4 bar real into a 3 bar frame. Or that the frame can be changed from a low wheel rubber rake to the high steel wheel rake? I have done all these changes. I have rebuilt JD, McC. Case, Moline, MH rakes,never had a Coop but New Idea parts work for them. Oliver and AC never made a steel wheel ground drive rake.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
