Truck Hauling Question
Goto page 1, 2  Next
OliverKid26
PostPosted: Thu Dec 07, 2017 4:31 pm    Post subject: Truck Hauling Question Reply to specific post Reply with quote
Hey guys looking for some advice.
I am looking to buy a 3/4 ton truck as a second vehicle. It would likely get 5,000 to 10,000 miles a year. I would use the truck as a farm truck hauling wagons, etc, but would also like to be able to haul my Oliver tractor that weighs about 9500 pounds to shows, parades, plow days, etc. My question is, will a 3/4 gas truck be able to haul this on a fifth wheel trailer? I don't want to beat on the truck too bad. Would I be much better off with a diesel? Interested in your guys thoughts. I know the gas trucks are much cheaper to maintain, but the diesels hold their value better, haul better, and last longer.
Wondering if I should go gas or diesel. Would prefer to get a Dodge that is a few years old regardless of if I buy gas or diesel.
caterpillar guy
PostPosted: Thu Dec 07, 2017 4:36 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
Ultimately Your choice, but for those few miles I would not worry about whether it is one or the other.
OliverKid26
PostPosted: Thu Dec 07, 2017 4:40 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
So I can haul a 9500 pound tractor on a 5th wheel with a gasser and be ok? I won't be hauling in mountains just small hills and mostly flat ground.
504
PostPosted: Thu Dec 07, 2017 4:53 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
Sure, twenty years ago half of the semi grain haulers were still gas. My 96 Chevy and camper gross out at 13,500#, with a 350 gas and automatic transmission.
MikeinKy
A good 3/4 ton truck and a gooseneck trailer will be just fine. I have a diesel now, but I had a ford V10 and a Ford with a 460 and they did good. For local hauling about any engine will get the job done, safely, just not as fast.
Huskergreen
PostPosted: Thu Dec 07, 2017 4:56 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
I have a 2008 Dodge 2500 with the 5.7 hemi auto that I pull a 25 ft. goose neck and have hauled a 1655 oliver, 1855 oliver, and 1950 oliver and it works ok. Just one at a time. LOL
moresmoke
PostPosted: Thu Dec 07, 2017 4:57 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
I have a V10 Ford. Haul 2 tractors around to the pulls all summer long. 28000 gross. Get 1 mpg less than the previous diesel.
dpendzic
PostPosted: Thu Dec 07, 2017 5:08 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
depends on the torque of the engine and the rear axle ratio
oliver power
PostPosted: Thu Dec 07, 2017 5:16 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
If you don't tow every day, get a gasser. If you do tow every day, get a diesel.
OliverKid26
PostPosted: Thu Dec 07, 2017 5:21 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
That is really good to know. I am leaning towards the gasser now after hearing that. How bad is the milage hauling? I am guessing it gets down in the 7-10 range when hauling a tractor?
M Nut
PostPosted: Thu Dec 07, 2017 5:35 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
I pull a 25ft 14,000lb trailer with that much weight, or more, and have no issues at all. Chevrolet 2500 with a 6.0 liter gas engine. I don't win races, but have pulled that much weight 300+ miles at a time on numerous occasions. No problems.
tractorsam
PostPosted: Thu Dec 07, 2017 5:38 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
A gas will do fine. I have a 3/4 ton and use a goose neck trailer. Usually up to about 12000lbs on the deck. It does fine, doesn't accelerate as fast as a diesel and you feel the hills a bit more but after a string of diesels new and old I'm happy with the gas truck. The first time you have to put a set of injectors or other major repair on an electronic diesel it'll suck up more than you'll save in fuel. Best of luck, Sam
Hobo,NC
PostPosted: Thu Dec 07, 2017 5:56 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
I think 4play put it about as good as it could be put in another post about would you buy a gas a diesel truck. About all I can add to that is if you are not willing to spend 5K on it don't buy it no matter what reputation the combination is...
Most all modern 3/4 ton trucks will get'er done as long as its powered well...
OliverKid26
PostPosted: Thu Dec 07, 2017 5:59 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
Definitely not trying to win any races! Just trying to be able to haul equipment safely. I appreciate the input.
OliverKid26
PostPosted: Thu Dec 07, 2017 6:00 pm    Post subject: Re: Truck Hauling Question Reply to specific post Reply with quote
What is the most that can be hauled legally with a 3/4 ton truck?
Goto page 1, 2  Next
Page 1 of 2
