1650 Hydra-Power front seal.
brutus49DC
PostPosted: Thu Dec 07, 2017 6:17 pm    Post subject: 1650 Hydra-Power front seal. Reply to specific post Reply with quote
I am trying to get the front bearing support off so I can replace the front seal. The shaft and support will come out about an inch but I can't get the input shaft to stay behind. It is solidly attached to the front support. Not sure if I have an early or later unit but I did the same thing a year ago without any problems. My I&T lists two different procedures but isn't real clear on either. I wish I had never tried to replace the seal but we are putting in a clutch and wanted to replace the seal as preventative maintenance. The tractor number is 193759 if that helps. Where is the serial number on the h-p unit?
cobroller
PostPosted: Thu Dec 07, 2017 7:34 pm    Post subject: Re: 1650 Hydra-Power front seal. Reply to specific post Reply with quote
You probably have a late style-if so the input shaft has to come out with the front cover, then remove the bearing retainer and shaft.
J. Schwiebert
PostPosted: Thu Dec 07, 2017 9:00 pm    Post subject: Re: 1650 Hydra-Power front seal. Reply to specific post Reply with quote
Serial number of the unit is stamped very close to the dipstick tube and is a 5 digit number and yes you have the late style unit.
brutus49DC
PostPosted: Fri Dec 08, 2017 4:05 pm    Post subject: Re: 1650 Hydra-Power front seal. Reply to specific post Reply with quote
what holds the shaft in? does the side cover need to be removed?
