Belt pulley and PTO Extender
Royse
PostPosted: Wed Dec 20, 2017 1:59 pm    Post subject: Belt pulley and PTO Extender Reply to specific post Reply with quote
Might be a good deal if you're interested in them.
Not mine, not affiliated. CraigsList - $40 for the pair
Kirk-NJ
PostPosted: Wed Dec 20, 2017 2:10 pm    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
Good deal,even has the bracket for cordwood saw. That $25 buck
to someone who needs one
Dean
PostPosted: Wed Dec 20, 2017 2:15 pm    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
Good deal, even for the 1 1/8" PTO pulley but shipping will be expensive.
Dean
Leroy
PostPosted: Wed Dec 20, 2017 4:36 pm    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
When I think of PTO extender it is to converta 1 1/8' pully to work on a 1 3/8" shaft tractor. I don't consider the shaft an extender as it was required for most any PTO powered machine, that is before the 3 pt mowers.
Dean
PostPosted: Wed Dec 20, 2017 5:05 pm    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
Don't know of any Ford N series PTO extenders that were also 1 1/8" to 1 3/8" converters.
Dean
flembo
PostPosted: Thu Dec 21, 2017 3:40 am    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
Last summer I paid $75 for a ford belt drive without the bracket so I had to make one.
Tim PloughNman Daley
PostPosted: Thu Dec 21, 2017 5:16 am    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
I have several of both, no need for any more but this is a helluva deal regardless. Yep, the special bracket attached is used only with the Cordwood Saw as no top link is required to run it. The saw has a 'wishbone' bracket that pivots and attaches to the pulley bracket. On the PTO Extender, I think they do go from 1-1/8 to 1-3/8 spline. I'll have to check my manuals but I'm pretty sure they were used on Dearborn implements like corn pickers, harvesters, spreaders, and combines that had the newer ASAE (American Society of Agricultural Engineers) 1-3/8 splined implements. My ad brochure says the extender was so newer implements could be used on the older Ford Tractors with standard PTO. I'll have to check one of mine next time I'm at the farm...
Tim Daley(MI)
Leroy
PostPosted: Thu Dec 21, 2017 7:35 am    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
What I think of as an extender was just a block about 3" lond that bolted to the tractor and you bolted the belt pully to it and had just a short piece the was 1 3/8" on side that went on shaft in tractor with 1 1/8" on the end that went into the belt pully so you could use your old pully made for a 1 1/8" shaft on the tractor that was changed to the 1 3/8" so that the coupler from a 3 point rotary mower that would have fit the JD and Oliver with the bigger shaft to the older Ford tractors tha orignally came with the small shaft. But I think the later Ford tractors had a 1 3/8" shaft in tractor and that was to be able to put your 9N belt pully on your 800 tractor instead of buying a new pully. And the PTO shaft pictured was used for pull type implements. Ysed one on the 44 2N to power the combine and corn picker, also a flail green choper. You did not use it with the mounted mowers tho. I have 2 of those shafts, one for each tractor and also a belt pully.
Leroy
PostPosted: Thu Dec 21, 2017 8:04 am    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
Getting this 74 year old brain working again. The CORRECT name for the shaft he has is EXTENSION and not extender as the extension puts the end of shaft at correct position to work. To me extender puts it farther back and changes things so the PTO shaft would not align correctly. So an extender would be used between tractor and the extension. The correct name for what I was thinking he had is Conversion block and is only for use with the pully and not a shaft. And those conversion blocks are very scarce. Most would instead of buying that conversion block when buying a newer tractor with the standard size shaft in if they needed a pully would just buy the newer one with the big shaft so it would just bolt on without a lot of bother and putting that conversion block in made it so you needed a different belt for the mounted saw that used the bracket on the pully. That bracket on the pully made it so that lifting saw would loosen the belt and lowering it would tighten the belt. So it comes down to not factory name being used that confused me.
Scott(Ks.)
PostPosted: Fri Dec 22, 2017 9:43 pm    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
Years ago when I was using a small AC baler I had the extension that went from 1 1/8-1 3/8 shaft. It bolted to the four bolts on the power take off housing. I also had the V shaped drawbar with stay bars. It worked very well. I later put in a 3/8 inch shaft and a swinging drawbar.
Leroy
PostPosted: Sat Dec 23, 2017 3:38 pm    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
That is when you needed that extender or conversion to still use that same PTO extension on the newer eqyiped tractor.
Kirk-NJ
PostPosted: Tue Jan 02, 2018 1:23 am    Post subject: Re: Belt pulley and PTO Extender Reply to specific post Reply with quote
This is probably the extension block you were talking about.
Or maybe this type
