traction belt on 510 MF
olgentdc
PostPosted: Wed Dec 20, 2017 4:00 pm    Post subject: traction belt on 510 MF Reply to specific post Reply with quote
i need to adjust the 510s belt before i road it tomorrow ,,.. does anyone know how ??. THanks JIM
gbs
PostPosted: Wed Dec 20, 2017 4:21 pm    Post subject: Re: traction belt on 510 MF Reply to specific post Reply with quote
if it isn't missing there should be a decal on the variable speed pulleys that gives the steps
Dieseltech
PostPosted: Wed Dec 20, 2017 5:10 pm    Post subject: Re: traction belt on 510 MF Reply to specific post Reply with quote
What gbs said, and you will need the wrenches to rotate the transmission and re-adjust the square shift rod. Hopefully the belts are not worn so much they are already bottomed in the pulley grooves, if so you may never get them tight enough to pull any hills. That's what happened on the last one I scrapped out, barely made it home..
mtf
PostPosted: Wed Dec 20, 2017 5:33 pm    Post subject: Re: traction belt on 510 MF Reply to specific post Reply with quote
Be sure and loosen set screw on the gear shift linkage before you adjust belts. On my 550 there are 3 bolts to loosen on tranny, before you adjust nuts. Tighten set screw back. Make sure before you start that you can shift all 4 gears.
olgentdc
PostPosted: Thu Dec 21, 2017 8:47 pm    Post subject: Re: traction belt on 510 MF Reply to specific post Reply with quote
thanx guys ,,This 510 wont stay in 2nd ,, so i fear, this may be a repeat of a another problem i have already seen... .gonna put this one off til i get better info ,,.about those shifting linkages,. i know we messed up a 510 tranny 40 yrs ago ,,.because the P-owner fouled up the linkage ,. probably , same holds true on my 300 diesel..
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
