Broken Wheel Clamp Studs
albent_33
PostPosted: Thu Dec 21, 2017 8:56 am    Post subject: Broken Wheel Clamp Studs Reply to specific post Reply with quote
Hi, I have looked through the other threads and have found no definite answer. I recently picked up a 1941 farmall h with a 3 point hitch not running for $350. While i was taking off the front wheels, I snapped the stud that goes through the hub and wedge that is used to clamp the rim to the hub. The other 2 studs look rusted out near the hub. So my question is, how should I go about fixing this issue? Drill them out? Pound them out? Are they threaded into the hub or just stuck through? There is a square head on the back side of the hub. Thank you for you help!
glennster
PostPosted: Thu Dec 21, 2017 10:19 am    Post subject: Re: Broken Wheel Clamp Studs Reply to specific post Reply with quote
it is just a square head bolt. you can drive it out. replace it with a grade 5 or 8 hex head bolt.
albent_33
PostPosted: Thu Dec 21, 2017 7:19 pm    Post subject: Re: Broken Wheel Clamp Studs Reply to specific post Reply with quote
CVPost-glennster wrote:
(quoted from post at 11:19:42 12/21/17) it is just a square head bolt. you can drive it out. replace it with a grade 5 or 8 hex head bolt.
I tried that tonight and it still doesn't want to budge. I also applied heat and tried to bang it out. Should I drill it out now?
old
PostPosted: Thu Dec 21, 2017 7:42 pm    Post subject: Re: Broken Wheel Clamp Studs Reply to specific post Reply with quote
Once rusted in they can be bears to get back out. It may take a lot of ATF soaking and heat and or a press to pop them out
Bob
PostPosted: Thu Dec 21, 2017 8:52 pm    Post subject: Re: Broken Wheel Clamp Studs Reply to specific post Reply with quote
I'd blow 'em out with the smoke wrench in less time than it took you to type your post. Lacking that, and air hammer with a punch tip would probably rattle 'em out.
RCP
PostPosted: Fri Dec 22, 2017 4:08 am    Post subject: Re: Broken Wheel Clamp Studs Reply to specific post Reply with quote
I was able to find 1/2 x 3 square head bolts on Ebay for our Oliver, if they would work for you, I have extras.
Rich
