Allis chalmers d grader
Mckoch84
PostPosted: Thu Dec 21, 2017 5:42 pm    Post subject: Allis chalmers d grader Reply to specific post Reply with quote
Hello I'm new to the forum and just purchased my first allis chalmers it's a model d grader serial #D-3842 need help with information on the year the engine is a four cylinder gas will need carb rebuild and fuel tank cleaning
old
PostPosted: Thu Dec 21, 2017 7:45 pm    Post subject: Re: Allis chalmers d grader Reply to specific post Reply with quote
If I remember right that is a WD45 tractor engine so many parts are the same as the WD45 tractor
Mckoch84
PostPosted: Fri Dec 22, 2017 5:30 am    Post subject: Re: Allis chalmers d grader Reply to specific post Reply with quote
Thank you that makes parts a lot easier to find does anyone know the year I'm thinking it's a mid 1950s I'll try to upload some pics today
JMS/.MN
PostPosted: Fri Dec 22, 2017 11:44 am    Post subject: Re: Allis chalmers d grader Reply to specific post Reply with quote
The Model D was built from 1949-1965, and used the 226 cu in engine- same as the WD45, or 226 power unit. 58 brake hp. D-3842 is a 1954 model. There was also a "gasoline special", which had larger tires as well as a hyd operated blade circle.
Mckoch84
PostPosted: Fri Dec 22, 2017 12:22 pm    Post subject: Re: Allis chalmers d grader Reply to specific post Reply with quote
Great info thank you it is a manual rotate with 8.25 x 20 tires that will need replacing soon dry rotted pulled carb and cleaned and rebuilt it today checked points and plugs they look very good so hopefully have it ready to run soon
old
PostPosted: Fri Dec 22, 2017 4:49 pm    Post subject: Re: Allis chalmers d grader Reply to specific post Reply with quote
Just a tip. If you find you need to replace the plugs use NGK3112s they seem to work better with this alcohol gas we now have
DonBC
PostPosted: Tue Dec 26, 2017 9:22 pm    Post subject: Re: Allis chalmers d grader Reply to specific post Reply with quote
I no longer have my D grader or any of the related data or I could tell you exactly the year from the serial number. I guess the mid 50's but I am certain that someone that has the serial number listing will come up with an exact year.
