ignition
david troutman
PostPosted: Fri Dec 22, 2017 5:14 am    Post subject: ignition Reply to specific post Reply with quote
allis chalmers d15 series 2 does rotor need to be pointing towards number 1 cylinder to correctly set ignition points
Aaron SEIA
PostPosted: Fri Dec 22, 2017 5:46 am    Post subject: Re: ignition Reply to specific post Reply with quote
Points just need to be open to set point gap. Doesn't matter which is open.
AaronSEIA
old
PostPosted: Fri Dec 22, 2017 1:09 pm    Post subject: Re: ignition Reply to specific post Reply with quote
I is easier to adjust the points with the rotor off. In theory any of the 4 lubes on the distributor shaft work for setting the points and one should even check to make sure the points open the same on all 4 if one is having an odd spark problems
