K181 Kohler
Doc8246
PostPosted: Fri Dec 22, 2017 7:40 pm    Post subject: K181 Kohler Reply to specific post Reply with quote
Are the threads in the block for the exhaust 1in. NTP? Thanks Ron
Doc8246
PostPosted: Fri Dec 22, 2017 7:41 pm    Post subject: Re: K181 Kohler Reply to specific post Reply with quote
NPT
Bob
PostPosted: Fri Dec 22, 2017 10:27 pm    Post subject: Re: K181 Kohler Reply to specific post Reply with quote
Yes, they are pipe thread, 1" sounds right, but you'll know for sure when you get up close and personal with a 1" tap.
Doc8246
PostPosted: Sat Dec 23, 2017 6:27 am    Post subject: Re: K181 Kohler Reply to specific post Reply with quote
Thanks Bob for the reply. Ron
jeffcat
PostPosted: Sat Dec 23, 2017 4:45 pm    Post subject: Re: K181 Kohler Reply to specific post Reply with quote
Wait till he finds out what that 1in. tap costs. Just don't forget, you do NOT want to screw the nipple in all of the way tight!!!!!! Stop at your local electrical supply place and pick up three or four lock rings that are used for the fittings in electrical cabinets. Get the pipe and muffler lined up correctly and then a couple of taps with a screw driver and a little hammer to lock the ring. I also wrap some molly grease around the pipe before I screw it in. Next time it comes out without too much fuss.
T.R.K.
PostPosted: Sat Dec 23, 2017 4:46 pm    Post subject: Re: K181 Kohler Reply to specific post Reply with quote
I just ran into this on a 7hp. Cub Cadet:
Yes, they are 1" NPT.
I found out that if you are wanting to clean the threads, my pipe tap bottoms in the port before it begins to cut threads.
This is not a problem if your threads are good and just want to screw an exhaust pipe into the hole.
T.R.K.
PostPosted: Sat Dec 23, 2017 4:52 pm    Post subject: Re: K181 Kohler Reply to specific post Reply with quote
Don't want it tight?
In my case, the new pipe loosened up when it was hot anyway. It was a good thing I put those rigid conduit locknuts on there, I had to tighten them up again while it was hot.
