Best size tire for a Farmall H
DanH
PostPosted: Sat Dec 23, 2017 5:27 am    Post subject: Best size tire for a Farmall H Reply to specific post Reply with quote
What would be the best tire size to run on a Farmall H. The Tractor is basically stock. I?m using 12.4 -38 now that are Kelly Springfield with a 45 degree. Not sure if it will have enough power to turn 13.6-38 ? Any suggestions would greatly be appreciated.
535353m
PostPosted: Sat Dec 23, 2017 8:36 am    Post subject: Re: Best size tire for a Farmall H Reply to specific post Reply with quote
if you are "stock",you are basically stuck with smallest tire.A friend of mine with super H and 87 hp runs 18.4 x 38 and people laugh till they see Him pull. Happy Holidays.
High Octane
PostPosted: Sat Dec 23, 2017 12:01 pm    Post subject: Re: Best size tire for a Farmall H Reply to specific post Reply with quote
Where at?
mmfan55
PostPosted: Sat Dec 23, 2017 12:43 pm    Post subject: Re: Best size tire for a Farmall H Reply to specific post Reply with quote
If you're starting to pull the engine down now: the larger tires will likely put it down. It you appear to have power left, you may be okay. Every situation different. A stock H around here will usually power out before half track regardless of tire size.
PretendFarmer
PostPosted: Sun Dec 24, 2017 4:49 am    Post subject: Re: Best size tire for a Farmall H Reply to specific post Reply with quote
Tire size is largely dependent on track type.
If you aren't pulling real hard clay, giant tires can hurt you traction wise.
I would run 13.6-38's on my low geared H. They wouldn't grab worth anything till 6500lbs class around here.
All stock classes of course.
I had 12.4's on it and it was much more competitive in lighter classes.
VicS
PostPosted: Sun Dec 24, 2017 12:56 pm    Post subject: Re: Best size tire for a Farmall H Reply to specific post Reply with quote
How big a tire does your rules allow. 15.5x38. That is what I would run. I went to Tunica Southern Nationals this month. Had 14.9X38 tires. The rules there allow 16.9 x38 radials. 3.5 mph top cut. 3500 lbs I did get 4th. But you can bet I will have 16.9s or step up to 4 mph full cut. 18.4 x 38. I have them.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
