1975 david brown 990 pto arm shakes and disengages
Goto page 1, 2  Next
wallacegod
PostPosted: Mon Dec 25, 2017 10:39 am    Post subject: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
i have a 1975 david brown 990 works good only thing is when i engages pto to 540 arm shakes and the it disengages what can do that
RGMartin
PostPosted: Mon Dec 25, 2017 2:36 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
Does it do it in 1000 too?
If not probably a broken gear. If 1000 does it as well, could be a bearing. Either case it means pulling the pto box off and replacing it, or rebuilding it.
wallacegod
PostPosted: Mon Dec 25, 2017 2:58 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
did not try in the 1000 and where is the pto box
wallacegod
PostPosted: Mon Dec 25, 2017 3:10 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
is it a big job taking the pto box off
RGMartin
PostPosted: Mon Dec 25, 2017 3:20 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
The housing behind the rear axle is the PTO box. Not hard to swap out, but it weighs about 200 pounds.
wallacegod
PostPosted: Tue Dec 26, 2017 3:44 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
[quote="RGMartin"](reply to post at 16:20:21 12/25/17) [
i am 1 hours drive with tractor to closet tractor shop and how many hours at a shop to fix it -25 here
Case Nutty 1660
PostPosted: Tue Dec 26, 2017 6:39 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
I have pulled them and fixed them in a hour to a hour and half,, those are not bad at all to work on,, takes longer to drain the oil than pull the unit for me anyway but I have been at this a while
cnt
wallacegod
PostPosted: Tue Dec 26, 2017 7:06 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
ok so 2 to 3 hours to do would you have the bearing number esterior bearing is new and how many bearings r inside and is there anything else to change since its opened up
wallacegod
PostPosted: Tue Dec 26, 2017 7:08 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
exterior
Case Nutty 1660
PostPosted: Tue Dec 26, 2017 7:36 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
Should take you tot he parts book breakdown
cnt
990 DB pto parts link
wallacegod
PostPosted: Tue Dec 26, 2017 8:11 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
check the 1000 shakes but less will get through this snow storm then will get it towed to the shop will call later to get a time to get it done it only has 1100 hours and what is the best bearing to install inside
wallacegod
PostPosted: Tue Jan 02, 2018 11:58 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
that pto problem fixed now i have another problem there is oil around the 2 covers on the side of block and has oil leaking up to frame not much but you see its humide on frame
RGMartin
PostPosted: Tue Jan 02, 2018 12:25 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
Likely just tired 43 year old gaskets. You can try gently snugging the bolt in the center of each cover. Probably best to replace the gaskets when the weather gets better.
wallacegod
PostPosted: Tue Jan 02, 2018 12:27 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
can oil leak from those covers
RGMartin
PostPosted: Tue Jan 02, 2018 12:55 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
Yes. the lifters for the push rods and the return passages from the rocker cover are behind them.
Goto page 1, 2  Next
Page 1 of 2
