1975 david brown 990 pto arm shakes and disengages
Goto page Previous  1, 2, 3  Next
wallacegod
PostPosted: Tue Jan 02, 2018 7:15 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
RGMartin wrote:
(quoted from post at 13:55:31 01/02/1Cool Yes. the lifters for the push rods and the return passages from the rocker cover are behind them.
what can i use for now to seal i will order gasket tomorow snow storm 40cm of snow coming
wallacegod
PostPosted: Tue Jan 02, 2018 7:36 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
what do they call those small covers so i can order tomorow
RGMartin
PostPosted: Wed Jan 03, 2018 4:06 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
Tappet inspection covers.
wallacegod
PostPosted: Wed Jan 03, 2018 2:46 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
RGMartin wrote:
(quoted from post at 05:06:48 01/03/1Cool Tappet inspection covers.
ok thanks
wallacegod
PostPosted: Wed Jan 24, 2018 1:59 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
i thought the tractor garage opened my pto to fix they check it and they said did a setting now cant engage the 540 a weird sound but the
1000 no problem i want to take off the pto unit will do it myself is there anything special to unbolt before pulling the pto unit off so
nothing breaks
wallacegod
PostPosted: Wed Jan 24, 2018 2:06 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
no it does not do it in 1000 the 1000 is smooth but the 540 is rough what gear and bearings i have to get and all parts numbers and a phone number to buy
wallacegod
PostPosted: Wed Jan 24, 2018 6:52 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
and what gear do i have to change the case dealer all bearings r back order i am in canada
wallacegod
PostPosted: Thu Jan 25, 2018 5:20 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
a guy told me right behind the hydraulic filter there is 2 7/16 bolts for pump pipe to take that off before pulling pto unit off is that the right way to pull unit off
wallacegod
PostPosted: Thu Jan 25, 2018 5:22 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
i am taking the pto unit out this saturday would like help or info how to take the pto unit out
Bret4207
PostPosted: Fri Jan 26, 2018 5:19 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
It's been a few years since I pulled the PTO assy off my 990, but I don't recall having to work on anything outside of the PTO cover itself. It's not a bad job at all. But you have to be careful putting it back together and get the hyd pump gears messed right by bumping the starter so that it slides in correctly. If you don't you can chip the gear teeth or break the gears and that get's expen$ive.
wallacegod
PostPosted: Fri Jan 26, 2018 4:08 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
ok a guy said there 2 7/16 bolt under for hydraulic pipe a brass fitting he said to take off before pulling the pto unit off he said its right behind the hydraulic filter cover and is there a way to line up pump gear so it wont chip the gear like a special way to do it and is it better to pull the pto unit strait out or if it tilts a little does it matter i dont want to break nothing i found the bearing with snap ring the one you cant get no more RBL makes them
wallacegod
PostPosted: Fri Jan 26, 2018 6:41 pm    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
does it take a gasket between the pto unit and rear end
wallacegod
PostPosted: Sat Jan 27, 2018 4:38 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
i checked this morning when i drained the hyd oil i think what the guy was telling for 2 7/17 bolt it looks like a small switch with wire right under the pto in back there is nothing behind hyd oil filter cap thats the only 2 7/16 bolts i see
RGMartin
PostPosted: Sat Jan 27, 2018 5:50 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
Cut the heads off of 2 6" long bolts, screw them in holes on opposite sides of the housing, and use them as guide rods to slide the PTO box off and on. It makes meshing the gears and aligning easy versus fighting it while trying to hold up the heavy gear box.
Bret4207
PostPosted: Sat Jan 27, 2018 7:03 am    Post subject: Re: 1975 david brown 990 pto arm shakes and disengages Reply to specific post Reply with quote
wallacegod wrote:
(quoted from post at 23:41:51 01/26/1Cool does it take a gasket between the pto unit and rear end
Yes, but form a gasket goo works fine.
Page 2 of 3
