F Cub how to remove clutch pivot bushing
Jlpb61
PostPosted: Wed Dec 27, 2017 9:57 am    Post subject: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
Major grinding noise when clutch pushed in. Thanks to ever one I have now split my first tractor. Found couple chunks out of throw out bearing, clutch coming apart and pivot bushing mostly gone. How is the best way to remove what is left of this bushing?
old
PostPosted: Wed Dec 27, 2017 10:15 am    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
Pivot bushing???????????????????? Do you by chance mean the pilot bearing?? There is a special adaptor made to go on a slide hammer just to pull them. O'Reilly's will rent you one if you do not have one. Since I already had the slide hammer I broke down and bought one not long ago for my slide hammer. Cost me around $17
Loren in Iowa
PostPosted: Wed Dec 27, 2017 10:33 am    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
If you really are referring to the pilot bushing, in the end of the crankshaft, then I have a trick you might try. Not sure about your specific tractor, but this has worked on car engines. Pump the area inside the bushing full of grease, from a grease gun. Use a shaft, or a socket and extension, as close to the hole diameter, as possible. Drive the shaft into the hole with a hammer, and the grease should push the bushing out.
john *.?-!.* cub owner
PostPosted: Wed Dec 27, 2017 12:05 pm    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
I have removed one by threading a die into it, don't remember the size, but it hit the bottom of hole and pushed the bushing out. There is a website dedicated to the cubs at farmallcub dot com.
Loren in Iowa
PostPosted: Wed Dec 27, 2017 2:20 pm    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
Quite likely, you threaded a tap into it.
PostPosted: Wed Dec 27, 2017 7:22 pm    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
CVPost-Loren in Iowa wrote:
(quoted from post at 17:20:02 12/27/17) Quite likely, you threaded a tap into it.
yup, mind went on a brief vacation.
K-Mo
PostPosted: Thu Dec 28, 2017 3:23 am    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
Haven't used one, but here's an example from Harbor Freight/
Pilot Bearing Puller
BarnyardEngineering
PostPosted: Thu Dec 28, 2017 4:24 am    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
If the bushing is as thin as you say, you should be able to collapse it by catching the edge of it with the corner of a sharp chisel, and tapping on the chisel with a hammer. Then you can grab it with some needle nose vise grips and pull it out.
Jlpb61
PostPosted: Thu Dec 28, 2017 7:09 am    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
Everyone
Thanks pilot pivot bearing ( bushing) you can tell i am new at this. But I am enjoying it. Thanks I will let you know how it goes
Jlpb61
PostPosted: Thu Dec 28, 2017 9:26 am    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
You got this right. I taped a pocket screw driver right under it. Split and came right out.
I am Waiting on my parts now.
roy prins
PostPosted: Sun Dec 31, 2017 5:03 pm    Post subject: Re: F Cub how to remove clutch pivot bushing Reply to specific post Reply with quote
fill the bushing with grease - find a shaft that fits the hole somewhat snug and smack it with a hammer-- two or three trys should push it out -- works every time -- Roy
