splitter hydraulics once more
Goto page 1, 2, 3, 4  Next
firhead
PostPosted: Thu Dec 28, 2017 7:16 pm    Post subject: splitter hydraulics once more Reply to specific post Reply with quote
I'm getting there but have a lot to learn. Am I to assume that the remote - as pictured - has an outflow port, the one on
the right with the notch, and an inflow port, the one on the left, and that I should connect the outflow port to the "IN"
port on the splitter valve? I do now have the closed center valve installed and plumbed on the splitter, but am having
trouble connecting it to the tractor.
David G
PostPosted: Thu Dec 28, 2017 7:53 pm    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
Either port can be in or out, ends are identical, just swap connections if lever does not go the way you want on the dash.
buickanddeere
PostPosted: Thu Dec 28, 2017 9:06 pm    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
You have not been listening. The front pump will cavitate with high flow loads because the SCV's return the oil to the transmission case.
SVcummins
PostPosted: Thu Dec 28, 2017 9:37 pm    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
You can hook it up ether way if when you move the lever the log splitter works backward from what you want swap the hoses on the tractor .
firhead
PostPosted: Fri Dec 29, 2017 8:50 am    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
I have been listening but perhaps not understanding. How does my choice of ports coming out of the remote effect
cavitation in the front pump by way of inducing high flow loads?
buickanddeere
PostPosted: Fri Dec 29, 2017 9:11 am    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
Have you not been reading the past 15 years of ytmag posts ? How do you think oil gets to the pump?
Larry in WNY
PostPosted: Fri Dec 29, 2017 9:33 am    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
Once the hoses are connected you need to use a strap or bungee to hold the lever open to get flow to the splitter valve. Splitters run better with a separate hydraulic pump either on the PTO or powered by a small gas engine. You need a separate oil tank to do that. I've heard running it from the tractor hydro pump can be rough on the pump. We did it that way until changing over to a PTO driven pump. External pumps have more flow and pushing power.
Larry
Tech 7
PostPosted: Fri Dec 29, 2017 10:20 am    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
Remind me again what model tractor we are dealing with.
firhead
PostPosted: Fri Dec 29, 2017 1:23 pm    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
2630
firhead
PostPosted: Fri Dec 29, 2017 2:10 pm    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
Larry
You've got it. I have found that bungeeing the lever open does the trick, and I also found I've got to keep my rpm up a little. Instinct tells me that using 70 horse to split a log is not the ideal; I hear that engine grunt a little and I'm thinking - wait, like you say, my neighbor's doing this with a Briggs and Stratton. Am I just moving an excessive amount of fluid through the system for the scope of the job? I mean the pressure we're dealing with here is the same, right - in the neighborhood of 2500 psi. Is there an electrical analogy to all this? Thanks.
Cliff
firhead
PostPosted: Fri Dec 29, 2017 2:12 pm    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
Larry
Cliff
firhead
PostPosted: Fri Dec 29, 2017 2:21 pm    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
Hey buickanddeere -take it easy. I've have NOT read the last 15 years of ytmag. I'm sure you are infinitely more
knowledgeable about this stuff than I am. Haven't been around it and am just coming to this forum to learn. In fact, still
trying to manage my posts properly.
cannonball
PostPosted: Sat Dec 30, 2017 5:09 am    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
What Buick is trying to say to you is the trans pump will not keep up with front pump..If I remember right you have two lines that had a loader hooked to them, put a closed center valve on splitter and hoop up high pressure to in and fliter cover to out...Tractor must be not running to hook up and unhook..I split with a 2840 that I hooked up to use a home made splitter on..works good...you can run off remotes but you will get intermittent movement..
Tx Jim
PostPosted: Sat Dec 30, 2017 5:21 am    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
CVPost-cannonball wrote:
(quoted from post at 08:09:02 12/30/17) What Buick is trying to say to you is the trans pump will not keep up with front pump.
I think whether trans pump can maintain enough flow while splitting with splitter plugged into scv breakaway coupler would depend on size of cylinder on splitter & speed desired of splitter operation.
Yes returning splitter valve oil to ported filter cover or rockshaft return line would be the best way.
Tech 7
PostPosted: Sat Dec 30, 2017 7:17 am    Post subject: Re: splitter hydraulics once more Reply to specific post Reply with quote
What will make this work really well, with no oil heating or pump cavitating is a selective control valve return oil kit, part #AR71945. If you need more help e-mail me.
Page 1 of 4
