Author |
Message |
TNFARMKID Regular
Posted: Fri Dec 29, 2017 10:08 am Post subject: Gleaner A-330 on F combine? |
Has anyone ever run this combination? I have found the head near me and I am considering going to narrow rows? My main concern is will the head work on the combine with 23.1x26 tires and not be hitting the adjacent rows? |
Back to top |
JMS/.MN Tractor Guru
Posted: Fri Dec 29, 2017 12:50 pm Post subject: Re: Gleaner A-330 on F combine? |
You can mount the tires dish in or dish out. Just do some measuring and chalk the rows on the tires, then check another 30 inches out....compare to head width. |
Back to top |
Bob Bancroft Tractor Guru
Posted: Fri Dec 29, 2017 1:10 pm Post subject: Re: Gleaner A-330 on F combine? |
Neighbor had an early F with 18.4x26 tires and a 330 head. He got tired of running down corn and got a 430 head. Should be 430 heads available.
I rebuilt the 330 to fit an E, then K2. |
Back to top |
centash Tractor Guru
Joined: 01 Nov 2014 Posts: 3611 Location: southern ontario canada
Posted: Sat Dec 30, 2017 7:06 am Post subject: Re: Gleaner A-330 on F combine? |
You can probably find a black frame 430 easily and for the same money....and be happier in the end as well. Ben |
Back to top |
Posted: Sat Dec 30, 2017 11:07 am Post subject: Re: Gleaner A-330 on F combine? |
I had an orange 430 head on the F2, with 28L-26 tires. They stuck out a bit on each side of the head, but were ok if you planted straight. Carried extremely well in mud. |
Back to top |
paul Tractor Guru
Posted: Sat Dec 30, 2017 12:55 pm Post subject: Re: Gleaner A-330 on F combine? |
I farmed a lot with a 4-38 head, ran a little bit with a 4-30 head that seemed tight - the ladder ticks the corn on the next row with 4-30. (To be fair my F turned into an F2 turned into an F3 each with wider stance and fatter tires.....)
I've seen a pair of 3-38 heads for an F on auctions they sure looked tight.
Not sure 3-30 would really work?
Paul |
Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 14256 Location: Delta,colorado
Posted: Sun Dec 31, 2017 7:53 am Post subject: Re: Gleaner A-330 on F combine? |
Drag out your tape measure and measure the width of the combine at it's widest point. The wheels can often be reversed to reduce width.120" is the width you will have to get between. |
Back to top |
