MF 253 Power Steering Pump
Goto page Previous  1, 2
gbs
PostPosted: Mon Jan 01, 2018 6:04 pm    Post subject: Re: MF 253 Power Steering Pump Reply to specific post Reply with quote
we have 2-253's and they have a relief valve some where in the system because you can here it open, I don't think you can use a gear driven pump without some type of relief without damaging the pump, go online to agco parts book, click on guest user and enter your tractor model,there you will be able to find the correct part numbers and view a parts diagram, the 253's if I remember correct had a couple of different style steering set-ups both of ours have the small cylinders mounted on each side of the front axle, with this style 1500# with sufficient flow would easily steer a 253.
Walter Buller
PostPosted: Tue Jan 02, 2018 4:40 pm    Post subject: Re: MF 253 Power Steering Pump Reply to specific post Reply with quote
Thanks gbs. I'll check them out. My 253 has the two small hydraulic cylinders up front just like yours. Like I said. The new pump worked perfectly for about an hour. So maybe it was just a defective pump.
Page 2 of 2
