2N 3 point will not stay down
allenlane
PostPosted: Fri Dec 29, 2017 8:20 pm    Post subject: 2N 3 point will not stay down Reply to specific post Reply with quote
Got my hyd pump all put back together and now my 3 point will not stay down. It raises and lowers fine but when I release the control it comes back up. Do I just need to calibrate the quadrant?
Mark over in Iowa
PostPosted: Fri Dec 29, 2017 9:03 pm    Post subject: Re: 2N 3 point will not stay down Reply to specific post Reply with quote
There is a cork shaped disc that goes between where your control lever is attached to your tractor, there is a chance that this has gone bad. The handle will want to rise up if your cork disc has gone bad. You can get a sheet of cork at walmart or any hobby store and cut it out and place it in there and it will create the friction to keep the lever down.
47fivewindow
PostPosted: Sat Dec 30, 2017 5:29 pm    Post subject: Re: 2N 3 point will not stay down Reply to specific post Reply with quote
I found some fiber washers I think were for a Woods mower blade. Corrected that problem.
View user's profile AIM Address
allenlane
PostPosted: Sun Dec 31, 2017 6:14 pm    Post subject: Re: 2N 3 point will not stay down Reply to specific post Reply with quote
That was it fellas. I made a washer out of some cork gasket material, works like a champ. Many thanks.
Mark over in Iowa
PostPosted: Sun Dec 31, 2017 9:26 pm    Post subject: Re: 2N 3 point will not stay down Reply to specific post Reply with quote
The guys on this forum helped me out with this same problem a few years ago, replaced it and haven't had a problem since. Glad it solved your problem too.
