4020 Hard Starting
Goto page 1, 2, 3  Next
2510Paul
PostPosted: Sat Dec 30, 2017 11:57 am    Post subject: 4020 Hard Starting Reply to specific post Reply with quote
The 4020 I am working on to fix the steering problem I described earlier, it starts really hard, even at 60 F in my shop. We pulled and tested the batteries, good. Connections all look good.
The starter could be suspect, the owner had it worked on this last summer. The owner feels the shop he used is good and others I trust not so much. There was a post on a 3020 about starters. I think Tim S recommended a Starter. Tim S or anyone else, can you recommend a good starter for a 1967 4020?
Also, this 4020 was overhauled last winter, not me. It is putting out 110 HP. It smokes light blue smoke a lot, even when raking or just idling. Could the pump settings, e.g. fuel rate or timing contribute to hard starting? I would like the owner to take it to the local diesel shop to get tuned up but so far he is not interested.
Paul
pms
PostPosted: Sat Dec 30, 2017 1:25 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
Is the starter dragging/engine not spinning fast enough?Or is engine spinning fast enough just not starting right away?
Paul
2510Paul
PostPosted: Sat Dec 30, 2017 1:57 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
The first. Paul
SVcummins
PostPosted: Sat Dec 30, 2017 2:28 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
Put a Dixie electric starter on my 3020 it is made in Canada
erskine2017
PostPosted: Sat Dec 30, 2017 3:08 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
"Connections All Look Good" has been the downfall of many who have electrical problems. The ONLY way to test connections and cables is with a VOLTMETER while the system is under load. The ONLY definitive way to check batteries is to charge them and take them to a shop that has a heavy duty carbon pile tester. The battery is loaded at half its CCA for 15 seconds and the voltage must not drop below 9.6 volts in order to pass.
tim s
PostPosted: Sat Dec 30, 2017 3:09 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
A Nipendenso starter is about the best,,and do you wiggle the steering wheel a bit when you start it,, this helps a lot too,,others will chime in and tell you to put a destroking valve on it,, but it's simpler to jiggle the steering wheel and you don't need to get back off the sea to deal with the valve... I use the little Iskra's a lot but the Nipp is better..
2510Paul
PostPosted: Sat Dec 30, 2017 5:15 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
Tim, where do you get the Nipendenso starter? I will Google but any direction you can give would be appreciated. Paul
2510Paul
PostPosted: Sat Dec 30, 2017 5:21 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
I assume Denso is the same thing. Paul
tim s
PostPosted: Sat Dec 30, 2017 6:27 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
Any starter shop should be able to get you one..
2510Paul
PostPosted: Sat Dec 30, 2017 6:39 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
I should point out this 4020 has been converted to 12V. I have been looking through the JD Parts but voltage is not specified. I am assuming the earlier serial numbers (before 201,000) are 24v starters, e.g. TY6703) and those after are 12v starters. In the serial number range after 201,000 there are both Delco and Denso brands and many offerings.
My question is how do I know which 12v starter will fit this engine? This tractor is Serial Number T213R 148221R, 1967 Model. The number cast into the engine block is R40890R
Paul
SVcummins
PostPosted: Sat Dec 30, 2017 10:02 pm    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
Abilene machine
JDEM
PostPosted: Sun Dec 31, 2017 7:03 am    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
What does "star hard" mean? Cranking like it should and not firing? Or cranking too slow? BIG difference.
Denso or Delco spin the same speed. Denso is just a little more rugged.
What is the RPM at cranking and voltage AT the starter-power-post when cranking?
Do you have a hydraulic pump destroker and are you using it? Some 4020s would not hardly crank-over right when new without that destroker.
D-
PostPosted: Sun Dec 31, 2017 7:17 am    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
Your starter looks like a 24V. The 12V
starters are longer. That 24V won't crank
as fast on 12V.
I would check injectors for that smoke problem.
Would affect starting also.
DONMYEIL
PostPosted: Sun Dec 31, 2017 7:26 am    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
Check the timing and the SPEED ADVANCE for correct setting . If the steering is calling for oil ,the hyd. pump will load the starter causing it too not crank as fast . I suspect you have leaking or low pressure injectors .
JDEM
PostPosted: Sun Dec 31, 2017 7:38 am    Post subject: Re: 4020 Hard Starting Reply to specific post Reply with quote
Steering problems often result in very hard and slow cranking and lots of burnt up starters. Install a $10 pump destroker and use it.
As far as the injection-pump goes and smoking all the time? Was the max delivery screw just turn in or were there other mods done to the pump? Have you checked the automatic fuel-timing advance that is supposed to advance timing as the RPMs go up?
Page 1 of 3
