4010 John Deere LP starter replacement
Mtractor
PostPosted: Sat Dec 30, 2017 12:59 pm    Post subject: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
What is the best replacement starter for a 4010 LP ( propane) I can get ? I see all kinds on the internet. I have been told mine is not rebuildable.
rick deere
PostPosted: Sat Dec 30, 2017 4:43 pm    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
Is it 12 volt or 24 volt? email is open
rick deere
PostPosted: Sat Dec 30, 2017 4:46 pm    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
look o ebay you can get new one for less than 200 and free shipping, that's a good price.
Mtractor
PostPosted: Sat Dec 30, 2017 9:24 pm    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
LP (propane) was only 12 volt or 6 volt never 24 volt. Thanks
D-
PostPosted: Sun Dec 31, 2017 7:10 am    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
Yours can probably be rebuilt. Where are you?
What is the Delco number? One from a gasoline
tractor is heavier I think and will work.
Check the salvage yards.
Those cheap gear reduction starters are for
diesels. I'm not sure there is one made for
the gas engines. If there is it will be cheaper
than rebuilt.
DONMYEIL
PostPosted: Sun Dec 31, 2017 7:18 am    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
We have a shop close by that can rebuild starters and alternators , electric Motors etc. If they don't have a part they can make it .Reasonable as well. By the way a true L.P. starter is much heavier than a gas .
D-
PostPosted: Sun Dec 31, 2017 3:15 pm    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
I guess I had that backwards. I have a former LP that is now on gas.
The starter that was on it is smaller than the one I put on from an
old gas and than the other gas I have. Tractors that old could have
had things switched over the years.
SVcummins
PostPosted: Sun Dec 31, 2017 6:17 pm    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
Here?s what the small gear reduction starter looks like compared to the oem style starter the gear reduction does spin the engine a little faster seems to be fairly well built
tractorguy2
PostPosted: Sun Dec 31, 2017 6:48 pm    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
I have used those reduction starters on 4430's,4640's and Case 730. They work very well. Only problem is they sometimes need longer battery cables.
4010 puller
PostPosted: Wed Jan 03, 2018 3:17 am    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
Where did you buy your starter from?
Mike M
PostPosted: Wed Jan 03, 2018 11:58 am    Post subject: Re: 4010 John Deere LP starter replacement Reply to specific post Reply with quote
The 4020 gas and diesel starters take different tooth count on the starter drives so be careful ! I am guessing the 4010 is the same way.
Right now our 4020 gas has a starter on it from a model 500 diesel. It was 24 volt so I converted it too 12 volt. IIRC new field coils and a new solenoid. Armature stays the same. Then I installed the gas starter drive which has a different tooth count and now it turns over better than ever.
