oliver 770 engine rotation direction
Goto page 1, 2  Next
Ron force
PostPosted: Sat Dec 30, 2017 2:24 pm    Post subject: oliver 770 engine rotation direction Reply to specific post Reply with quote
what is the engine rotation of a oliver 770 clockwise or counter clockwise? thanks in advance for your help !!
rrlund
PostPosted: Sat Dec 30, 2017 2:54 pm    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
Clockwise from the front.
Ron force
PostPosted: Sun Dec 31, 2017 6:02 am    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
thank you sir!!
old
PostPosted: Sun Dec 31, 2017 9:31 am    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
Just for your info 99% or all engine spin the same direction
rustred
PostPosted: Sun Dec 31, 2017 10:15 am    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
when viewing engine rotation it is taken as looking at the flywheel, or the rear of engine. so it would be classed as counter clockwise.
the same is when talking left or right side of an engine. it is taken when viewed looking at flywheel from behind.
plus think of the hand crank engines,.. you are cranking them clockwise standing in front ,but they are still classed as counterclockwise rotation.
rrlund
PostPosted: Sun Dec 31, 2017 10:27 am    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
That's as confusing as buying auger fliting. lol
Bob
PostPosted: Sun Dec 31, 2017 1:12 pm    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
"That's as confusing as buying auger fliting"
NOT sure what might be confusing there, RH auger flighting is coiled/angled just like the threads on a standard RH thread bolt.
rrlund
PostPosted: Sun Dec 31, 2017 1:49 pm    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
I called and ordered some for the grinder mixer. For some reason,when I told him the direction of rotation and the direction it was moving the material,it just seemed counter intuitive to me.
oliver90owner
PostPosted: Sun Dec 31, 2017 2:49 pm    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
Certainlybforvauto. Engines and most tractors but have you ever watched any videos of old aero engines?
Oliver made one tractor with an engine that would run both ways. They withdrew it because it ran over the farmers!
RAB
old
PostPosted: Sun Dec 31, 2017 6:37 pm    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
That is why I said 99% which of course is not all of them. I do not know if they still make them but at one tire some of the older gulf carts use an engine that would run forward and backwards to get forward speeds and backward speeds. Also some of the old Detroit diesel would run backward and if one had one start and it was running backward you learned fast to shut it down and try again
rustred
PostPosted: Sun Dec 31, 2017 7:54 pm    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
what about inboard boat motors... those were opposite rotation.
old
PostPosted: Mon Jan 01, 2018 7:51 am    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
Think about it they would fall into that 1% which with all the engine there are MADE WOULD STILL BE A LARGE NUMBER
Neil Grant
PostPosted: Mon Jan 01, 2018 8:26 am    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
I always think of it as hand cranking it after that to see.
rustred
PostPosted: Mon Jan 01, 2018 10:32 am    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
that has been the standard probably since the auto's came out. left and right sides of engines , and rotations. are classed as sitting in the seat or standing behind.
J. Schwiebert
PostPosted: Mon Jan 01, 2018 1:31 pm    Post subject: Re: oliver 770 engine rotation direction Reply to specific post Reply with quote
Not all. When I worked for Dana we had marine engine kit catalogs and many engines had camshafts for both right and left hand rotations. Also many old Detroit diesels are left hand rotation engines for older buses and industrial rotations.
Goto page 1, 2  Next
Page 1 of 2
