WD45 throttle rod ,adjuster fittings
RalphWD45
PostPosted: Sat Dec 30, 2017 8:24 pm    Post subject: WD45 throttle rod ,adjuster fittings Reply to specific post Reply with quote
I have misplaced the two adjusting fittings, that tighten down, on my two piece throttle rods. that run on the right side of the engine, from the govener to a bell crank, by the gas tank, and then on back from the bell crank , back to the hand throttle, at the steering post. These two fittings, fit in the bell crank, and accept the 1/4 " throttle rod, and the 1/4" govener rod. The throttle speed is set by adjusting the length of the 1/4" rods by tightening the fittings , on the rods, to the desired speed. I have looked in Stiners catalog, and Tired Iron's catalog, and can't find them. Does any of you guys know of a source for these? This is a 1955 AC WD45., and is ready to come out of the shop, and go to work!
hd6gtom
PostPosted: Sat Dec 30, 2017 9:44 pm    Post subject: Re: WD45 throttle rod ,adjuster fittings Reply to specific post Reply with quote
If nobody answers here post this on the unofficial Allis forum.
D beatty
PostPosted: Sat Dec 30, 2017 9:51 pm    Post subject: Re: WD45 throttle rod ,adjuster fittings Reply to specific post Reply with quote
Is this what your looking for? If so DJS tractor parts has new ones listed.
RalphWD45
PostPosted: Sun Dec 31, 2017 12:43 am    Post subject: Re: WD45 throttle rod ,adjuster fittings Reply to specific post Reply with quote
Thanks so much D Beatty! That is exactly what I am needing! I have never known about DJS tractor parts, till now. They are closed, for the holidays, till the 2nd, but will be ordering from them Tuesday. THANKS AGAIN GUY!
16-30 oilpull
PostPosted: Sun Dec 31, 2017 2:55 am    Post subject: Re: WD45 throttle rod ,adjuster fittings Reply to specific post Reply with quote
D Beatty, a sweet 45 ,Rick
old
PostPosted: Sun Dec 31, 2017 9:15 am    Post subject: Re: WD45 throttle rod ,adjuster fittings Reply to specific post Reply with quote
I have found things like those at a farm and home store and or a good hardware store
old
PostPosted: Mon Jan 01, 2018 10:45 am    Post subject: Re: WD45 throttle rod ,adjuster fittings Reply to specific post Reply with quote
I was in O'Reilly's this morning and saw those in there HELP area as I was looking for push nuts
