Steering cylinder mount and trans question.
Goto page 1, 2  Next
corelokt
PostPosted: Sun Dec 31, 2017 4:52 pm    Post subject: Steering cylinder mount and trans question. Reply to specific post Reply with quote
Looking for the steering
cylinder mount on the
tractor.
Also, tried to pull the
tractor today. Both rear
wheels are locked up.
Shifter was in neutral and
the hi low lever wouldn't
move. Pushed the clutch
in and that did nothing
too.
riveroadrat
PostPosted: Sun Dec 31, 2017 5:14 pm    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
What make and model of tractor? That will steer you in the right direction. Do you need a steering cylinder bracket or need to know where it is?
corelokt
PostPosted: Sun Dec 31, 2017 7:01 pm    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
I need a bracket.
corelokt
PostPosted: Sun Dec 31, 2017 7:03 pm    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
It's a ford 3000, made in 1975
riveroadrat
PostPosted: Sun Dec 31, 2017 9:04 pm    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
I dont have any parts for that model. It sounds like your tranny is in 2 gears at the same time. I dont know about those trannys, maybe someone will chime in on the fix for that.
Destroked 450
PostPosted: Sun Dec 31, 2017 11:16 pm    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
One end of the steering cylinder connects to the radius rod and the end connects to the drag link, there is no bracket on that model unless it has aftermarket steering or is an industrial model that used a different steering system.
List the numbers from the foil sticker under the hood or the ones stamped into the transmission housing, their located on the flat surface behind the starter.
That will help us better understand what your working with.
corelokt
PostPosted: Mon Jan 01, 2018 9:38 am    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
Ok, thanks.
corelokt
PostPosted: Mon Jan 01, 2018 10:02 am    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
Here's pics
Destroked 450
PostPosted: Mon Jan 01, 2018 10:35 am    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
No pics.
corelokt
PostPosted: Mon Jan 01, 2018 10:41 am    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
It's a diesel!
corelokt
PostPosted: Mon Jan 01, 2018 10:47 am    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
Ser C044585
Engine 4j24a
Model c01013c
Hyd pump 4k04a
Trans 4k24b
Hyd lift 4k24b
R. Axle 4k230
Unit 4l25b
Destroked 450
PostPosted: Mon Jan 01, 2018 11:23 am    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
Model # C01013C isn't correct
Model # C1013C is for a 3000 all purpose diesel with live pto and 8 spd trans.
Serial # C044585 is for a 65 model not 75
Does it have vented hood panels or smooth side
3000 power steering uses 2 cylinders , one one each side connected to the radius rods and drag links.
Some after market kits use one cylinder on the left side mounted to a bracket that bolted to the engine where it connects to the transmission.
Which system do you have?
Sean in PA
PostPosted: Mon Jan 01, 2018 5:21 pm    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
I do not think that it is a 1965 tractor.
C044585 is not a correct serial number. They started the thousand series US serial numbers in 1965 with C100001. So a serial number starting with C0 was never made.
Also, the model number starts with a letter, which indicates that it was made after 4/1/1968.
The unit number, engine number, trans number, etc. all start with a 4, which says that the tractor was made in a year ending in a 4. The unit number being 4L25B means that it was made on November 25 in a year ending in a 4, so it is most likely a late 1974 tractor, and the serial number is most likely C445xxx, which would be a late 1974 serial number.
Destroked 450
PostPosted: Mon Jan 01, 2018 7:42 pm    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
I stand corrected. Seen all the zeros for the beginning 65 models and missed the 1
The 0 in the serial number is probably like the 0 in the model number, it doesn't belong there.
corelokt
PostPosted: Mon Jan 01, 2018 11:10 pm    Post subject: Re: Steering cylinder mount and trans question. Reply to specific post Reply with quote
It looks to be a drag link mount and the end of the steering cylinder. Both busted.
Goto page 1, 2  Next
Page 1 of 2
