Farmall M
Goto page 1, 2  Next
Andrew Leibold
PostPosted: Sun Dec 31, 2017 5:19 pm    Post subject: Farmall M Reply to specific post Reply with quote
I bought a farmall M to restore i was told it was a 1941 but i am not sure and i can not make sense out of any of the numbers. I took pictures of everything can someone please help me figure out all the numbers and letters so i know more about this tractor and what the year is? I was told it was a combine too and it seems to have the mounts for one
Janicholson
PostPosted: Sun Dec 31, 2017 5:24 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
You will need to ask permission from Kim (left on "Feedback Forum" this prevents inappropriate images from being posted by nasties.
Jim
Andrew Leibold
PostPosted: Sun Dec 31, 2017 5:29 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
i cant find it
John M
PostPosted: Sun Dec 31, 2017 5:46 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
What does the serial number tag have on it? I suspect its a cotton harvester, not a combine.
D beatty
PostPosted: Sun Dec 31, 2017 5:57 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
This is where serial number is if it still has tag.
fastfarmall
PostPosted: Sun Dec 31, 2017 6:04 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
You probably have to find what year it is by the date codes, casted into the castings, like 6-10-M, means June 10th 1941
tractorguy2
PostPosted: Sun Dec 31, 2017 6:32 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
What's the formula to get the year 41 out of the letter "M"?
John M
PostPosted: Sun Dec 31, 2017 7:11 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
K is 41, IIRC.
Cory Schmidt
PostPosted: Sun Dec 31, 2017 7:38 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
IH used letters for year coding cast parts...the month and day cast were numbers then year a letter...FastFarmall must of hit a wrong button someplace....here is the list
fastfarmall
PostPosted: Sun Dec 31, 2017 8:48 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
ok, K
Andrew Leibold
PostPosted: Sun Dec 31, 2017 10:46 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
49098 is whats left of the serial number
Andrew Leibold
PostPosted: Sun Dec 31, 2017 10:48 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
almost al of mine say J after the date and none of them r the same
Andrew Leibold
PostPosted: Sun Dec 31, 2017 10:50 pm    Post subject: Re: Farmall M Reply to specific post Reply with quote
i was told it was a two row cropper
D Slater
PostPosted: Mon Jan 01, 2018 3:37 am    Post subject: Re: Farmall M Reply to specific post Reply with quote
49098 may be all the serial numbers. That would be built the last month of 41. J code cast parts would be cast in 1940. If several or most are J code that makes it doubtful on serial number and castings matching. even if cast in the last month of 1940 that serial number puts them around a year apart. If original the engine may have the same serial number as the chassis around that time period. Should have several K codes with that serial number and very few if any J codes.
Andrew Leibold
PostPosted: Mon Jan 01, 2018 6:07 am    Post subject: Re: Farmall M Reply to specific post Reply with quote
The engine says FBK- 23659 rightabove the distributer its pretty warn down but right underneath that number it almost looks like there id a /1. Does it matter if all the cast dates are different but they all have J? Also is it possible that it was bought in 1940 as a 1941? By the way thank you everyone for your help i really appreciate it.
Andrew Leibold
Goto page 1, 2  Next
Page 1 of 2
