Hydraulic post hole digger / auger need advice
sdk8
PostPosted: Mon Jan 01, 2018 7:45 am    Post subject: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
Hi everyone. I want to build a direct drive hydraulic post hole digger to use on my very old skid steer. Home Depot rents towable units (Ground Hog brand) that just use a hydraulic motor to power the auger, no gear box, direct drive. I want to do a similar setup. My skid steer has auxiliary hookups (never used them) Thinking about getting an ebay hydraulic motor, 1" shaft, about 23 cubic inch displacement. 10 feet 1/2" hoses. Thinking about mounting the motor to a steel plate, weld a piece of 6" pipe about a foot long to plate (enclosing motor) then rig up a swivel at top of pipe, attach to bucket. Will it work? Thoughts? Thanks
Bob
PostPosted: Mon Jan 01, 2018 8:09 am    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
You would have to know available flow and pressure from the skid, then divide the flow by the displacement of the motor to give you the speed. Looking at the chart from the motor mfg. will give you the torque the motor will produce at the available pressure.
At that point, it would be helpful to have an idea of how much torque it takes to operate the your particular auger to dig at a useful speed in your soil conditions.
Or, you could figure this out empirically buy trying that motor and adjusting the size up or down as needed $$$!
old
PostPosted: Mon Jan 01, 2018 8:20 am    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
Bob you hit the points as to why I have not tried to take my old post hole digger and putting on a hyd motor I have laying around. Gear box on my post hole digger striped the gears so it sits doing nothing and I traded for 2 hyd motors years ago and they just lay around in my shop and there brand new never used with the factory plugs still In the ports
sdk8
PostPosted: Mon Jan 01, 2018 8:45 am    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
Bob thanks. According to the info I have the pressure is Main 2130 psi, Port 1560 psi, and discharge volume is 7.37 gal per minute. Any advice is much appreciated
Tony in SD
PostPosted: Mon Jan 01, 2018 8:59 am    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
There are a few more things to consider. The constant vertical pull/push on a direct mother that may not be designed for that force may
prematurely fail. Torque of the motor, the ability to turn the auger. Not sure of your soil types or diameter of the holes, so you will need to
match your flow, torque, auger size and soil conditions.
No matter what you end up with, you will be much happier with a skid steer PHD than a 3 point PHD any day.
sdk8
PostPosted: Mon Jan 01, 2018 9:27 am    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
Tony thanks.
I agree with the push pull concerns, that's why I was very surprised with the units Home Depot rent. There's not much to them! I look at it like, they rent them to everybody and their brother and apparently they hold up.
I know they aren't hooked to a skid steer but if I put a rig together and use with a good bit of caution I might be ok?
buickanddeere
PostPosted: Mon Jan 01, 2018 2:38 pm    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
couls be cheaper to just purchase a hydraulic post hole digger than to cobble something together while hoping the specs are correct . http://www.danuser.com/category/product-category/attachments/auger-systems/hydraulic/ep-heavy-duty-series
jeffcat
PostPosted: Mon Jan 01, 2018 5:05 pm    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
If I remember correctly the Ground Hog units have a metal bar that is
hooked to the power unit. That keeps you from getting tourqed in with
everything. Just remember those little hydraulic motors can put a
world of hurt on you. Personally a cobble project like this gives me
an uneasy fealing.
used red MN
PostPosted: Mon Jan 01, 2018 9:58 pm    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
Don?t know about all the technical problems you will have to overcome but here is one thing I will recommend, to mount the digger somehow incorporate a universal joint from an old drive line or PTO shaft. One yoke mounted to your stationary mount to the bucket the other yoke attaching to the auger motor or drive unit. This will hold everything from turning but allow any angle.
2x4
PostPosted: Mon Jan 01, 2018 10:36 pm    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
Agreed. $2500 will get you a new Lowe auger (no relation to Lowes Store) with a warranty & long time reputation for working.
jeffcat
PostPosted: Tue Jan 02, 2018 9:07 am    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
Down at work we have very big cooking kettles with power mixers on them. They can crush up whole lobsters like soup crackers. Bent the ever lovin crap out of a stainless paddle. Had to use an angle grinder to get it apart. Most hydraulic stuff is not really fast but most of the time it also DOESN'T stop. Crunch!
buickanddeere
PostPosted: Thu Jan 04, 2018 11:49 am    Post subject: Re: Hydraulic post hole digger / auger need advice Reply to specific post Reply with quote
Who ever specified the hydraulic motor errors and used too high of torque rating.
Or install a variable relief valve to limit pressure and therefore torque.
