880 oliver
brian stanek
PostPosted: Mon Jan 01, 2018 10:39 am    Post subject: 880 oliver Reply to specific post Reply with quote
can anyone tell me where the level plug is for the rear diff and trans. on an 880 oliver. all I see is a 1/4 inch plug on the pto housing. I put in too much oil I think. 1/2 way up axle shafts and it is leaking out by the brakes?
Ohio88
PostPosted: Mon Jan 01, 2018 12:06 pm    Post subject: Re: 880 oliver Reply to specific post Reply with quote
brian stanek wrote:
(quoted from post at 11:39:47 01/01/1Cool can anyone tell me where the level plug is for the rear diff and trans. on an 880 oliver. all I see is a 1/4 inch plug on the pto housing. I put in too much oil I think. 1/2 way up axle shafts and it is leaking out by the brakes?
It is on the right below and back from the axle.
J. Schwiebert
PostPosted: Mon Jan 01, 2018 1:26 pm    Post subject: Re: 880 oliver Reply to specific post Reply with quote
On the 880 tractor the check plug is on the right ahead of the axle. Did you drain both the transmission and the final drives? Capacity for both of those is 19 quart.
brian stanek
PostPosted: Mon Jan 01, 2018 3:02 pm    Post subject: Re: 880 oliver Reply to specific post Reply with quote
yes I drained both trans and rear diff. will look again but all I have seen is the brake housing,
J. Schwiebert
PostPosted: Mon Jan 01, 2018 6:03 pm    Post subject: Re: 880 oliver Reply to specific post Reply with quote
Look in front of the brake housing for a pipe plug.
brian stanek
PostPosted: Tue Jan 02, 2018 11:41 am    Post subject: Re: 880 oliver Reply to specific post Reply with quote
so I seen the plug but just assumed it was so low in the system it was a drain plug on the side. thanks for the info.
4010 puller
PostPosted: Wed Jan 03, 2018 3:21 am    Post subject: Re: 880 oliver Reply to specific post Reply with quote
Is that the same capacity for a 88, I thought they were 18 quarts?
brian stanek
PostPosted: Thu Jan 04, 2018 8:46 am    Post subject: Re: 880 oliver Reply to specific post Reply with quote
CVPost-4010 puller wrote:
(quoted from post at 12:21:44 01/03/1Cool Is that the same capacity for a 88, I thought they were 18 quarts?
I don't know what the capacity would be. I just thought the plug in front of the axle seemed a bit low to be a level plug but maybe it is the one.
