8n oil pump clearance
wilber
PostPosted: Mon Jan 01, 2018 11:01 am    Post subject: 8n oil pump clearance Reply to specific post Reply with quote
What is the clearance on 8n with 3/4 gears.from gear face to pick up tube face.and if the clearance is to
large can you leave out the gasket and use peratex in its place.
TheOldHokie
PostPosted: Mon Jan 01, 2018 12:24 pm    Post subject: Re: 8n oil pump clearance Reply to specific post Reply with quote
CVPost-Wilber wrote:
(quoted from post at 15:01:33 01/01/1Cool What is the clearance on 8n with 3/4 gears.from gear face to pick up tube face.and if the clearance is to
This has been discussed at great length recently. Measure the face width of your gears - they should be .724/.725. If they are even a few thousandths under that you are the lucky recipient of the bogus ones flooding the market - likely supplied by Atlantic Parts. The Atlantic gears come in close to .713/.714 and there is nothing you can do to make them work properly. You will have excessive end clearance and the pump won't make proper pressure or maintain prime. Return them telling the seller they are defective and purchase new ones from a different source. The Tisco kits are harder to find but they have the proper face width. One source for them is Just 8 N's.
TOH
