Case 580 B hoe end problem
D Alan
PostPosted: Mon Jan 01, 2018 4:46 pm    Post subject: Case 580 B hoe end problem Reply to specific post Reply with quote
I have a 1971 Case 580B.
It has been a great old tractor but today the boom, dipper, and bucket quit working. I was loosening up some ground with backhoe to be able to scoop up and move when it just stopped functioning.
Front bucket, and outriggers work fine. There is no busted hyd. Lines tho it does leak around the seals on the controll box but no worse thsn it has for a long time. What should i check?
dacaseguy
PostPosted: Mon Jan 01, 2018 5:02 pm    Post subject: Re: Case 580 B hoe end problem Reply to specific post Reply with quote
Sounds like it has to be in the stack of valves down under between your legs. There is. Several O Rings and relieve valves. Do you have a
parts book and a repair manual. Your probably going to have to remove that valve bank. You will need to remove the backhoe to get to it.
Someone else might have a better idea. If your stabilizers are working that tells me that it's not an oil supply problem because your getting oil to
the valve bank if your stabilizers are working. Dick
dacaseguy
D Alan
PostPosted: Mon Jan 01, 2018 5:26 pm    Post subject: Re: Case 580 B hoe end problem Reply to specific post Reply with quote
Thanks Dick
So you think its not in the control box the leavers go into?
Your thinking its in the assembly under that right? I will keep watch and see if anyone else has a suggestion.
But your right its not the pump or oil as everything but the boom dipper n hoe bucket works fine...
I dont have a book for this machine so ill have to hunt one up
Case Nutty 1660
PostPosted: Tue Jan 02, 2018 1:23 am    Post subject: Re: Case 580 B hoe end problem Reply to specific post Reply with quote
Your pump splines on the hyd pump are toast, the pump and all drive pieces need replaced
cnt
Case Nutty 1660
PostPosted: Tue Jan 02, 2018 1:29 am    Post subject: Re: Case 580 B hoe end problem Reply to specific post Reply with quote
SORRY I missed that bucket and loader works as it should I was half asleep reading sorry
cnt
dacaseguy
PostPosted: Tue Jan 02, 2018 4:14 pm    Post subject: Re: Case 580 B hoe end problem Reply to specific post Reply with quote
Your levers go to a tower between your legs with a horizontal shaft running across it. The bottom of each lever has another short lever hooked to it that goes down to a valve . Each lever is connected to a valve. There should be 5 valves bolted together to create a stack of valves. There is O Rings between these valve sections that tend to leak but those are not your problem. There is something internal going on in with those valves that has caused you to loose 3 functions. There is some pressure release valves and other things. I'm hoping someone might chim in to indicate what the issue is. Dick in Oregon my ph is 541-787-5590
mEl
PostPosted: Tue Jan 02, 2018 5:22 pm    Post subject: Re: Case 580 B hoe end problem Reply to specific post Reply with quote
Do the stabilizers work or not or did you lose all rear function? Do not tear into the backhoe valve without checking the more obvious things out, if you have lost all rear functions the power beyond o ring could have blown on the outlet fitting on the loader control valve, this oring is place to direct the oil flow out of the loader control instead of returning to sump through the low pressure side of the loader control valve. It is the fitting that the large hose fastens to and goes to a quick coupler. Another possibility would be the regeneration valve having a broken spring or a stuck plunger. Please do not suspect the BH valve until you have exhausted the other possibilities, the only thing in the BH valve that should affect all systems would be the regen circuit and it IS contained in the BH valve section. Do not change any of the secondary reliefs as you can set up a potentially unsafe machine or do major damage to hoses, they are set by the dealer with a special fixture that pressurizes them and the popoff point is set to a specific spec depending on the system being checked.
