DC Sleeves are out #128076;
dacaseguy
PostPosted: Mon Jan 01, 2018 5:21 pm    Post subject: DC Sleeves are out #128076; Reply to specific post Reply with quote
I got the sleeves removed out of my DC 4 today. Good way to start the new year I figured. I only wanted to do a valve job and replace the piston rings. I figured I better check the sleeve O Rings and go ahead and put rings in it. Being a 1953, I was surprised it was 3 7/8 Pistons instead of 4 inch? Got the sleeves back in with new O Rings with a little help from som Vaseline. Kept the wood stove going and it was nice and toasty. Dick
tomturkey
PostPosted: Mon Jan 01, 2018 6:06 pm    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
Can you give us a few shots of the rod bearings as long as its apart. Just curious to how they look. You did not mention replacing them as you are only doing a valve job lol gobble
fixerupper
PostPosted: Mon Jan 01, 2018 6:32 pm    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
Replacing the Orings is good preventative maintenance. I had to replace the Orings in my SC after i found antifreeze in the oil pan. They held out for a good many years though.
Don Rudolph
PostPosted: Mon Jan 01, 2018 6:40 pm    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
Dick,
Does your motor serial number match your plate under the battery? Does your engine serial number have AP stamped before or after the number? Do you happen to have the buildcard info? Thanks, Don
casecollectorsc
PostPosted: Mon Jan 01, 2018 7:16 pm    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
Rod bearings on a DC Case are poured babbit not shell inserts.
dcinillinois
PostPosted: Tue Jan 02, 2018 1:31 pm    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
I have heard and have used dish soap to lube o- rings not sure about Vaseline as it is petroleum based and might break down o-ring any thoughts on this as when I break down my dc-3 I will want to do it right so any help would be great thanks did not mean to highjack any ones post
thanks Bob
dacaseguy
PostPosted: Tue Jan 02, 2018 3:58 pm    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
I've always used gasoline ? God or bad, I don't know. These new O Rings will outlas me, I know that much. I've done several case tractors using Vaseline. Dicl
dacaseguy
PostPosted: Tue Jan 02, 2018 6:32 pm    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
Not sure how my other post said I've used gasoline ? I think the computer corrected me. It should have said Vaseline not gasoline 🙀 Dick
Ron Sa
PostPosted: Wed Jan 03, 2018 8:51 am    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
The bottom side of these O-rings is exposed to motor oil. They have to be oil resistant.
kevinthefixer
PostPosted: Wed Jan 03, 2018 5:54 pm    Post subject: Re: DC Sleeves are out #128076; Reply to specific post Reply with quote
From the looks of the old 0-rings, replacing them was a good plan.
