2N ran 30 seconds, then clunk and tranny locked
Steve W(NY)
PostPosted: Mon Jan 01, 2018 7:26 pm    Post subject: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
I went out in 5 degree weather here in upstate NY and started my 2N. I was letting it warm up on high idle. The PTO was engaged and it ran about 30 seconds and then I heard a distinct clunking sound. I immediately knew it was bad and though rod. I couldn't turn over the tractor until I stood on the clutch and it started right up.
Letting out the clutch causes it to stall. I disengaged the PTO and it doesn't seem to matter. The bad part is it's squeezed into my un heated barn without a lot of clearance. She's been a reliable runner for in my hands for over 19 years. I was one of the original purchasers a Zane Thang but I haven't been to the board for years.
Any thoughts? Steps?
Take Care,
Steve
OBwan
PostPosted: Mon Jan 01, 2018 8:35 pm    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
Warm it up. Drag into a heated area or put some heaters on it. You may have a lot of water in the trans/diff fluid and it's frozen.
howdy1960
PostPosted: Mon Jan 01, 2018 9:55 pm    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
I agree with possible water in tranny.
Place a (space) heater under it and carefully tarp it to retain warm air.
Loosen a tranny plug enough to drain/drip off water, move space heater 1st.
I disengaged my PTO on my 2N last time out before starting just to make warm up easier.
I always start while stepping on clutch, give engine a 1-2 mins to warm up before coming off clutch.
Mine lives under a lean-to roof as no room to stuff even a snowblower in garage.
Kirk-NJ
PostPosted: Tue Jan 02, 2018 1:45 am    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
This tranny and hydraulics were also locked up. Although the water in yours may not be this bad it still can cause problems. Grad-jewel warmup might solve your problem. if so drain, clean and
replace fluid.
L.Fure
PostPosted: Tue Jan 02, 2018 7:00 am    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
It's going to take a lot of heat to melt the ice if the air temperature is in the single digits. You most likely will have to use either a kerosene forced air heater, or one that burns LP. Covering the tractor with tarps is a good idea, so you won't have to heat the whole shop to get it thawed out.
Steve W(NY)
PostPosted: Tue Jan 02, 2018 7:12 am    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
Thank you for your quick responses. I hope you are all right, but the fact it ran for 30 seconds and then clunk/stopped gives me a bit of worry. I'll tarp it and hit it with some heat tonight. It's been crazy cold.
Take Care,
Steve
L.Fure
PostPosted: Tue Jan 02, 2018 8:40 am    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
I used a 2 gallon tin bucket with charcoal bricketts in it to thaw out a JD model B. It took a few hours to get it warm enough so I could drain the water out of the transmission.
allenlane
PostPosted: Tue Jan 02, 2018 10:43 am    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
Is it common that water gets into these N's? How does it get there assuming all plugs, plates, etc are in place.
Bruce (VA)
PostPosted: Tue Jan 02, 2018 11:30 am    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
Contrary to conventional wisdom, not a lot of water gets in the oil from the shifter boot. The purpose of the shifter boot is to keep dirt out of the hydraulic sump. Of course, if it's bad, replace it, but you get water from the draft control spring & the dipstick. But, most water is just a byproduct of the heating/cooling cycle of the oil. The oil never gets hot enough (like engine oil) to boil off the water and it condenses inside the case. And, even when you aren?t operating the tractor, the oil and case heat and cool at different rates, also creating condensation.
75 Tips
L.Fure
PostPosted: Tue Jan 02, 2018 2:21 pm    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
All good reasons to keep the tractor under a roof when not in use. It will save you a lot of grief in the long run.
showcrop
PostPosted: Tue Jan 02, 2018 3:22 pm    Post subject: Re: 2N ran 30 seconds, then clunk and tranny locked Reply to specific post Reply with quote
allenlane wrote:
(quoted from post at 11:43:36 01/02/1Cool
Do you ever see condensation on any metal surfaces around your place? If so, it is condensing on the inside of your cases at the same time. Under normal work conditions the heat will drive the moisture out the same or next day. Under occasional use conditions it slowly accumulates more and more. A roof over it makes little difference.
