electricians--what is this?
farmerjohn
PostPosted: Tue Jan 02, 2018 2:52 am    Post subject: electricians--what is this? Reply to specific post Reply with quote
Remodeled a house recently and found these on the wall behind a cover plate, wires feeding the outlet box were dead, wires out led to under a window and cut off, maybe an old baseboard heater? They have a little button on the top, electric wholesale store did not know what they were. ??????
olddog
PostPosted: Tue Jan 02, 2018 3:10 am    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
Google micro switch.
Moonlite37
PostPosted: Tue Jan 02, 2018 4:08 am    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
Lightning arrestor for an outside antenna? Just a guess
jon f mn
PostPosted: Tue Jan 02, 2018 4:37 am    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
Called a micro switch. The button will either open or close the circuit
View user's profile AIM Address
Steve@Advance
PostPosted: Tue Jan 02, 2018 4:41 am    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
It's a switch.
Push the little black button, it will click, the contacts will open.
It's not all there, normally there would be a lever on top, something to actuate the button.
Very common item.
buickanddeere
PostPosted: Tue Jan 02, 2018 4:44 am    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
Sometimes installed to only allow the air conditioner to operate when the windows are closed . There are some people that for what ever reason. They think they want a window open for fresh air when the heating or cooling is operating.
flembo
PostPosted: Tue Jan 02, 2018 6:28 am    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
No it's all there it is as others said a Micro switch.
dr sportster
PostPosted: Tue Jan 02, 2018 8:33 am    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
I have micro switches like that on my drag bike to kill the ignition momentarily while the air cylinder pops it into the next gear.
Steve@Advance
PostPosted: Tue Jan 02, 2018 10:23 am    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
Technically...
"Micro Switch" is a brand name. They make hundreds, thousands, of different types of switches, photocells, electronic components.
The generic name would be a "plunger actuated snap-acting switch".
Typically found inside some type enclosure, used as a limit switch.
Ted in NE-OH
PostPosted: Tue Jan 02, 2018 6:19 pm    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
May be part of a burglar alarm system , circuit opens when window is opened to set off alarm.
old bc
PostPosted: Tue Jan 02, 2018 9:22 pm    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
It is a limit switch.
Switch
Isie Shank
PostPosted: Tue Jan 02, 2018 9:26 pm    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
Micro switch
used red MN
PostPosted: Tue Jan 02, 2018 9:51 pm    Post subject: Re: electricians--what is this? Reply to specific post Reply with quote
Better look for a new more knowledgeable electrical wholesaler. Lol. What did you do to the wall in the area you found the switches? Tap around on it is there a hidden safe there? Maybe the switches triggered and alarm when a painting was moved covering it. Humorous antidote I thought.
