861 PS question
William Fissell
PostPosted: Tue Jan 02, 2018 12:43 pm    Post subject: 861 PS question Reply to specific post Reply with quote
Hi,
rebuilt PS on my 861; new steering column from here, bearings, seals etc. New pump new cylinders. Works well but I get an upwelling of PS fluid out under the steering wheel if its cold or if I run it all the way lock to lock. I am thinking PS pressure is just a little too high and its blowing past the top seal.
Any thoughts?
thanks
Bill
riveroadrat
PostPosted: Tue Jan 02, 2018 2:18 pm    Post subject: Re: 861 PS question Reply to specific post Reply with quote
It shouldnt leak there at all, did you feel the seal slip past the outside edge? I always give a little back and forth motion while pushing the tube on. Was it good before it started leaking the first time? If it was good before, the pump shouldnt be the problem.
William Fissell
PostPosted: Tue Jan 02, 2018 2:28 pm    Post subject: Re: 861 PS question Reply to specific post Reply with quote
It was never 'good" as it was trashed when I got it with a seized pump are rusted through cylinders, pitted steering column. New springs and seals and bearings in the control valve, new pump, new tubing, new cylinders. Generally it leake when steering and not when the sterring wheel is not being turned.
Yes I felt the edge slide over easy. My only worry is I left too much travel up and down by not tightenign the nut enough.
Ultradog MN
PostPosted: Tue Jan 02, 2018 2:51 pm    Post subject: Re: 861 PS question Reply to specific post Reply with quote
What did the surface of the seal area on the shaft look like?
Did you put a speedi sleeve on it?
My first guess is that it might need a sleeve there.
Sean in PA
PostPosted: Wed Jan 03, 2018 5:00 am    Post subject: Re: 861 PS question Reply to specific post Reply with quote
CVPost-William Fissell wrote:
(quoted from post at 18:28:51 01/02/1Cool My only worry is I left too much travel up and down by not tightenign the nut enough.
There are specific instructions in the service manual for tightening that nut. I don't have the book handy, but from memory I believe that You are supposed to tighten it until snug/tight and then back off a certain fraction (1/6 or 1/4???) of a turn and then stake the nut in place.
William Fissell
PostPosted: Wed Jan 03, 2018 9:26 am    Post subject: Re: 861 PS question Reply to specific post Reply with quote
Brand new shaft from this site, looked good.
William Fissell
PostPosted: Wed Jan 03, 2018 9:33 am    Post subject: Re: 861 PS question Reply to specific post Reply with quote
yep and thats what I did; seems to me steering shaft ha a lot of vertical movement- maybe 1/4 or 5/16 as I turn it.
riveroadrat
PostPosted: Wed Jan 03, 2018 5:57 pm    Post subject: Re: 861 PS question Reply to specific post Reply with quote
Thats about how much they are supposed to move. When you turn the wheel one way the shaft and control valve spool moves up, turn the other way the shaft and spool moves down. Thats what redirects pressure for left or right turns.
