New Home Made Tool
Goto page Previous  1, 2
Brendon Warren
PostPosted: Wed Jan 03, 2018 9:57 am    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
I think a sursingle (sp) would work. You know the metal end from the strap that goes around the cow when using a Surge milking machine.
big tee
PostPosted: Wed Jan 03, 2018 10:37 am    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
Looks like a bull cinch to me---Tee
TimV
PostPosted: Wed Jan 03, 2018 1:33 pm    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
They certainly do, as that's exactly what we used at home. For those unaware, the link shows what a surcingle is--the metal part called the "triangle" is what we used--the strap had broken so we had it lying around. Bent a bigger hook in the end and used it for years. If memory serves, we bent it so it would lie flat when the triangle was pushed and pulled under the log--I think ACG is going to find his hook digs in and grabs on every root, rock, and other obstacle he encounters, but it still should beat doing it by hand.
surcingle
Dusty MI
PostPosted: Wed Jan 03, 2018 2:59 pm    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
CVPost-47fivewindow wrote:
(quoted from post at 18:03:22 01/02/1Cool Zipper puller upper?
For Paul Bynian ?
gab
PostPosted: Wed Jan 03, 2018 3:16 pm    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
You're right.
Adirondack case guy
PostPosted: Wed Jan 03, 2018 3:39 pm    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
I forgot about them. Yes very similar. They didn't have the T handle though, just a Z shaped end to lock into the eye of the strap. We had the Delavel sp. milkers which sat in the manger under the cows.
Loren
Adirondack case guy
PostPosted: Wed Jan 03, 2018 3:46 pm    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
Tim, I will tell you how it works next summer. I debated on which side off the bow to put the finger on. Figured when hooked,the choker would keep it from digging into the dirt.
Time will tell.
Loren
TimV
PostPosted: Wed Jan 03, 2018 4:09 pm    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
Any commercially-made one I've seen (attached link is just the first one I found, but they're all pretty much identical) has the hook bent flat, not at a 90-degree angle, but by all means give it a shot--it's not that big a job to redo if it doesn't work.
Logging Choker Grab Rod
allenlane
PostPosted: Thu Jan 04, 2018 12:34 pm    Post subject: Re: New Home Made Tool Reply to specific post Reply with quote
Nice job Loren! Thanks for sharing.
Page 2 of 2
