how is this supposed to work...
steve19438
PostPosted: Tue Jan 02, 2018 3:42 pm    Post subject: how is this supposed to work... Reply to specific post Reply with quote
i bought this many years and don't know if i ever used it. pipe warmer, but when i plug it in it does not get warm. light goes on in plug but no warmth. will it only warm when in contact with pipe ??
Sean Feeney
PostPosted: Tue Jan 02, 2018 3:52 pm    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
Could be junk or its set with internal thermostat, put it in the freezer for an hour and then plug it in and see if it warms up my.02
TimV
PostPosted: Tue Jan 02, 2018 3:54 pm    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
assuming you mean a heat tape, they don't get very hot. Too much fire risk if they did. They will still keep pipes from freezing if installed properly.
Duane WI
PostPosted: Tue Jan 02, 2018 4:32 pm    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
Possibly an impedance pipe heater.
Dan in North Houston
PostPosted: Tue Jan 02, 2018 5:19 pm    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
haven't had to use one of those heat tapes in many years (thank goodness), but I seem to remember that some had a thermostat built in, wouldn't heat up until the ambient temp was below a certain point.
farmall 400
PostPosted: Tue Jan 02, 2018 6:46 pm    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
I bought a new one last week and it says the thermostat must be in contact with the pipe my thermostat looks like a push button switch but does not push, hope that helps
steve19438
PostPosted: Tue Jan 02, 2018 7:06 pm    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
it took awhile but i finally found instructions for its use and you are correct.
steve19438
PostPosted: Tue Jan 02, 2018 7:07 pm    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
thanks fellas.
Bret4207
PostPosted: Wed Jan 03, 2018 5:42 am    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
Just an FYI, I've had pipes frozen when the ambient air temp was too high to get the tape working. Simple fix- took a chunk of ice and placed it against the thermostat on the tape and wrapped it in a rag. Got the tape to work!
steve19438
PostPosted: Wed Jan 03, 2018 9:30 am    Post subject: Re: how is this supposed to work... Reply to specific post Reply with quote
thanks for the tip. i did it and the cord do heat up.
