Hydraulic pump help
jonchip
PostPosted: Wed Jan 03, 2018 12:42 am    Post subject: Hydraulic pump help Reply to specific post Reply with quote
Is there a chance that someone might know what kind of pump this is? I have a 51 8n and the pump is from a Dearborn 19-8. I found the pump for the 19-8 but it is a little
different. As you can see from my pics the back is solid. And the original looks like it had a bolt or drain on the back. Sorry I don't have better pics but I thought I would
be able to find something with all the numbers it has on it and only took close ups.
TheOldHokie
PostPosted: Wed Jan 03, 2018 3:09 am    Post subject: Re: Hydraulic pump help Reply to specific post Reply with quote
CVPost-jonchip wrote:
(quoted from post at 04:42:59 01/03/1Cool Is there a chance that someone might know what kind of pump this is? I have a 51 8n and the pump is from a Dearborn 19-8. I found the pump for the 19-8 but it is a little
I do not recognize the pump. What are you trying to accomplish by identifying it?
TOH
jonchip
PostPosted: Wed Jan 03, 2018 11:26 am    Post subject: Re: Hydraulic pump help Reply to specific post Reply with quote
The pump works great but leaks out the front shaft seal. So I was wanting to know what pump just to make sure I order the right
seals or if they are even available.
TheOldHokie
PostPosted: Wed Jan 03, 2018 11:38 am    Post subject: Re: Hydraulic pump help Reply to specific post Reply with quote
(quoted from post at 15:26:01 01/03/1Cool The pump works great but leaks out the front shaft seal. So I was wanting to know what pump just to make sure I order the right
On a pump of that vintage shaft seals are pretty generic. Disassemble, measure the seal, and order based on size. If the seal leaks there is a good chance there is a mechanical reason behind it - e.g worn shaft and/or bearing...
TOH
