How much traction do you gain with chains?
Goto page Previous  1, 2, 3, 4  Next
JimB2
PostPosted: Wed Jan 03, 2018 1:04 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
Trygg, the best spike chains. We have used them since early 1970s. Put them on good and tight.
JimB
495man
PostPosted: Wed Jan 03, 2018 1:17 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
Pull behind snow blower you are fighting a losing battle in deep snow with a 2wd and no chains.
I used a normal 3pt blower on a 240 MF for a while, never ran chains on it, always carried the blower an inch or two off the ground in hard going to keep the weight on the tractor.
Had to blow snow downhill if icy. No front weights, could drive on the two rear wheels with front off the ground at will, so I could wade fairly deep snow steering with the brakes.
Have chains on the 2wd loader tractor, turns useless into useful. Have a well worn set of Norse(?) studded chains and even worn out they quadruple the traction.
Brad Buchanan
PostPosted: Wed Jan 03, 2018 1:19 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
Short answer: Like night and day
Brad
gab
PostPosted: Wed Jan 03, 2018 2:51 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
First year I had this tractor I didn't have any trouble until we had a bunch of ice, couldn't do anything. Found a set of these rough riding cross link chains for 50 bucks and it digs now.
300jk
PostPosted: Wed Jan 03, 2018 3:23 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
300 Farmall. 2 sets of wheel weights and double ring chains.
Clean my snow with a 7 foot blower. Never had traction
problems.
rohdog50
PostPosted: Wed Jan 03, 2018 4:20 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
Jim,
Been using my 1966 MF-135(Z145 gas)for over 45 years,to plow snow,this little massey will start in cold weather when nothing else will...I use to have chains on it...but it works fine with the back blade and loaded tires......it's been a blessing to have all these years,great little tractor.
cjunrau
I can't drive around here and feed with out chains. My driveway is up hill and curves and it don't matter how I tried to get up , slow , fast dif lock made no difference. put on chains and it don't matter no more. Chains are easy and cheap to make. Buy good chain at the local cheap place (Princess auto around here when on sale) and weld the cross chain in and no big deal. You can also just put 1 chain around each hole in the rim(6 usually) and that helps but is a little jerky for continues use. just don't put 1 through where the valve stem is. that system works great on trucks when they get stuck as its easy to put on.
BrianV_
PostPosted: Wed Jan 03, 2018 4:33 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
Wow, I wasn't expecting to come back and find my question had come out to 3 pages!
So, some context for others - I'm not really dealing with 'deep snow' where there's any risk of beaching the tractor... really, no more than a few inches at a time other than some drifts I need to deal with more carefully. However, I'm just not getting much grip in some areas.
This afternoon (after starting this thread), I pushed some snow out of my driveway with the loader, and the two front tires dropped 1" down into the ditch on the other when I pushed it across - not really 'into the ditch', but to flat ground 1" below the road surface. I could not get enough traction to back up. Even using the bucket to life the front tires and increase the rear weight. I eventually had to park my van at the end of the driveway and use a comealong to winch my tractor back up that 1" drop...
I'd discovered new small uphill portions of the driveway I had previously assumed to be flat simply because the tractor won't go up them unless I have intertia or the blower raised.
I'm thinking chains make sense. I found some sized for 12.4x28s locally. My tractor has 13.6x28 tires on it currently. Would they work with the tire 1.2" wider than the chains were designed for?
Eldon (WA)
PostPosted: Wed Jan 03, 2018 5:15 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
CVPost-cjunrau wrote:
(quoted from post at 17:20:45 01/03/1Cool I can't drive around here and feed with out chains. My driveway is up hill and curves and it don't matter how I tried to get up , slow , fast dif lock made no difference. put on chains and it don't matter no more. Chains are easy and cheap to make. Buy good chain at the local cheap place (Princess auto around here when on sale) and weld the cross chain in and no big deal. You can also just put 1 chain around each hole in the rim(6 usually) and that helps but is a little jerky for continues use. just don't put 1 through where the valve stem is. that system works great on trucks when they get stuck as its easy to put on.
Ha! Reminds me when I was a kid and made chains for my bicycle so I could ride it on the crick in the winter. I cut individual links of that cheap swing set chain and used electric fence wire to wire them on a soft tire, then added more air to tighten them up. Worked well....
mj
PostPosted: Wed Jan 03, 2018 6:40 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
Yep- Agree.
mj
PostPosted: Wed Jan 03, 2018 7:15 pm    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
rustyfarmall wrote:
(quoted from post at 10:54:17 01/03/1Cool
It is simple. If you are using your tractor for purposes of snow removal, you need chains.
Yep - I was spinning every time I stopped and tried to go again, until I took some time and 'hung iron'.
Smile
495man
PostPosted: Thu Jan 04, 2018 2:24 am    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
BrianV_ wrote:
(quoted from post at 17:33:18 01/03/1Cool I pushed some snow out of my driveway with the loader,
I must have missed the loader part before. A 2wd loader tractor is completely useless for snow and ice without chains.
If the 12.4 28 chains have stretched any (worn) they might fit.
Kirk-NJ
PostPosted: Thu Jan 04, 2018 3:58 am    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
It's possible they might fit your tractor. You might have to add some chain to make them fit. Lengthen is not usually a problem adding chain if the width is alright. Some thing to keep in mind is
what chains to what thread you have. Ladder style chains will work on 45 degree lug, bald or turf tires but on 23 degree thread will often fall between the lugs making them almost useless. The
duo-grip style or H style work better on the 23 degree lugs, hit the ling to view chains. I have had ladder chains that have also be adapted for better traction, see photo.
Depending on the snowfall some years I can get away without chains and some years I can't. I'm last minute so I always wait unless they are predicting a big snowfall before I put them on. If you
are just getting stuck every once in a while it might pay for you to find a pair of of these. They have work for me several times when I don't have my chains on. They fold up and are easy to
store.
45 degree ladder style with added chain
23 degree with ladder chains
Long/short bar with ladder chains with added chains for better traction
Tire chain link
DR. EVIL
PostPosted: Thu Jan 04, 2018 4:13 am    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
I doubt a 12.4x28 chain would fit properly and stay on a 13.6x28 tire. You can put a bigger chain on
smaller tires but going the other way, small chain on larger tire won't work.
You can cut and splice in a couple links in each cross chain and make them work. All depends on how good a
bargain the chains are.
Dad bought half a dozen pairs of semi-tractor tire chains and made chains for both of my tractors, Super H
and M. Without chains I can't even drive up my concrete driveway in an inch of snow. With chains I can
push an 80 inch wide blade 16 inches high full of snow up the driveway and across the road. Dad's chains
have cross chains every other link of the side chains. The chains for the Super H weigh over 200 pounds
for each chain, like adding over one more set of wheel weights but lets me push 4-5 times or more snow.
On my concrete drive it's a complete waste of time trying to push snow without chains. I used to clear my
driveway in town with a garden tractor mounted snow blower, chains were required on it too. But I've had
3-4 foot drifts here in the country, not playing with toys in snow like that.
RedMF40
PostPosted: Thu Jan 04, 2018 4:36 am    Post subject: Re: How much traction do you gain with chains? Reply to specific post Reply with quote
When I was in the market for chains for my tractor, I got on the phone with tirechains.com. The woman who helped me was very knowledgeable, knew what chains were best for different conditions. Some were better for ice/snow, others were more general purpose. They should have a number where you can reach them.
Page 3 of 4
