Tachometer Drive for alternator
Dennis (VA)
PostPosted: Wed Jan 03, 2018 9:20 am    Post subject: Tachometer Drive for alternator Reply to specific post Reply with quote
Have an old MF 202 which was converted to an alternator so Tach will not work. Is there any way to make it work or some type of kit available to put a drive on the alternator?
Dieseltech
PostPosted: Wed Jan 03, 2018 11:52 am    Post subject: Re: Tachometer Drive for alternator Reply to specific post Reply with quote
MF late 175-180 used an alternator with the tach gear drive, Some AC tractors did too, 190XT, 200, and probably others also.
russ1
PostPosted: Wed Jan 03, 2018 12:33 pm    Post subject: Re: Tachometer Drive for alternator Reply to specific post Reply with quote
I believe the parts list on this site has a tach gear for alternator.
Fred Werring
PostPosted: Wed Jan 03, 2018 4:41 pm    Post subject: Re: Tachometer Drive for alternator Reply to specific post Reply with quote
Have no idea how the tach drive is set up on this Massey, or if it would work, but there's alternators with tach drives available for Fords
Fred
Alternator for Fords on ebay
Welding man
PostPosted: Thu Jan 04, 2018 6:57 am    Post subject: Re: Tachometer Drive for alternator Reply to specific post Reply with quote
You have to be careful on these. Ford used 2 different dash assemblies, The tach turned clockwise on some and counterclockwise on others, Would have to verify rotation of the tach on MF.
wjytexas
PostPosted: Thu Jan 04, 2018 6:59 am    Post subject: Re: Tachometer Drive for alternator Reply to specific post Reply with quote
since it is already altered with the alternator why not get an electronic tach?
ptfarmer
PostPosted: Thu Jan 04, 2018 9:42 am    Post subject: Re: Tachometer Drive for alternator Reply to specific post Reply with quote
CVPost-welding man wrote:
(quoted from post at 07:57:57 01/04/1Cool You have to be careful on these. Ford used 2 different dash assemblies, The tach turned clockwise on some and counterclockwise on others, Would have to verify rotation of the tach on MF.
MF has CW, and CCW cable drive tachometers.
Fred Werring
PostPosted: Thu Jan 04, 2018 10:25 am    Post subject: Re: Tachometer Drive for alternator Reply to specific post Reply with quote
Just googled the tach for a 202, looks like the tach on it rotates clockwise (looking at the tach), same as my 4 and 5000's that had the generator/alternator tach drive.
Later model Fords (5600) had the tach driven off the oil pump, they rotated CCW.
Not saying it will work, but it might. I make no promises :)
Fred
