Mf 50 hx elecrtical problems
eurofarmer
PostPosted: Mon Jan 08, 2018 2:26 pm    Post subject: Mf 50 hx elecrtical problems Reply to specific post Reply with quote
My 50hx wil not start, batery is food an charged but there is no power at the ignition switch. No controle lights come one when you turn the
switch. The tractor does start when using an srewdriver on the starter. It does not drive, no electric to the valves. The fuses in the fuse box
located in the cab are ok. Also I did clean the conectors on the left hand front side of the cab.
I do not have a wiring schema for this tractor, does anybody know if it has some inline fuses and at what location?
Thank you
Danielfire50
PostPosted: Mon Jan 08, 2018 7:53 pm    Post subject: Re: Mf 50 hx elecrtical problems Reply to specific post Reply with quote
The older 50 models had two inline 30 amp fuses a few inches behind the starter on the wires coming off the battery feed. I don't know if the newer ones are that way.
eurofarmer
PostPosted: Mon Jan 08, 2018 11:03 pm    Post subject: Re: Mf 50 hx elecrtical problems Reply to specific post Reply with quote
No, it must have changed Daniel, after the starter the wiring goes straight into the wire loom. They must be in a different location, but I am running out of options. Hard to believe I have a broken wire, the loom seems intact and never had any issues before with this tractor.
Danielfire50
PostPosted: Tue Jan 09, 2018 9:06 am    Post subject: Re: Mf 50 hx elecrtical problems Reply to specific post Reply with quote
I wonder if they used fuseable links. It's common for automobiles to have fuseable links feeding the fuse box.
eurofarmer
PostPosted: Sat Jan 13, 2018 3:48 pm    Post subject: Re: Mf 50 hx elecrtical problems Reply to specific post Reply with quote
After days of working on it(not fulltime)and getting frustrated with it found a broken wire behind a connector at the bottom of the cab.
So it is working again. No extra fuses on this model, I did find a schema in the end that was useful.
