9n ignition switch left on
Goto page 1, 2  Next
davidbrodhead
PostPosted: Wed Jan 10, 2018 9:09 pm    Post subject: 9n ignition switch left on Reply to specific post Reply with quote
I left my ignition switch on by mistake. Battery was dead when I discovered my error. What has been damaged ?
Tony in SD
PostPosted: Wed Jan 10, 2018 9:54 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
More tan likely the points. Maybe the coil too.
Richard from SE AZ
PostPosted: Wed Jan 10, 2018 10:37 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
If your tractor still has the cut out relay, take out the points unit and replace it with a diode ( bridge rectifier ). I did that to mine about five years ago and even after leaving the key on a number of times when tinkering with it, I have never had a dead battery. The diode only allows current in one direction. I will post a picture tomorrow of a spare I set up and have not had to use.
Bob
PostPosted: Wed Jan 10, 2018 11:46 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
The "cutout" in the charging system has NOTHING to do with draining the battery on an otherwise properly functioning tractor that has suffered the misfortune of it's operator being careless/forgetful and leaving the switch on.
At that point (engine stopped) it should have already disconnected the generator from the battery.
Tony in SD
PostPosted: Thu Jan 11, 2018 1:09 am    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
I agree with Bob, nothing to do with the regulator if it is operating properly.
I?m talking about the ignition points in the distributor not relay contacts in the regulator.
Tim PloughNman Daley
PostPosted: Thu Jan 11, 2018 3:39 am    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
Points are probably burned up -pull distributor and rebuild, do not need any fancy components, OEM stock is just fine. While at it get battery tested, replaced if necessary, and fully charged if still good.
Tim Daley(MI)
cowdog
PostPosted: Thu Jan 11, 2018 4:25 am    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
Why don't you just charge the battery and try and start it before you start throwing parts at it.
Bruce (VA)
PostPosted: Thu Jan 11, 2018 4:55 am    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
As cowdog said, charge the battery (see tip # 60) & try to start it. If it doesn't start see, tip # 38.
75 Tips
Clifford B.
PostPosted: Thu Jan 11, 2018 11:13 am    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
CVPost-cowdog wrote:
(quoted from post at 05:25:44 01/11/1Cool Why don't you just charge the battery and try and start it before you start throwing parts at it.
My thoughts also, been there myself and it fired right up after a recharge.......
HFJ
PostPosted: Thu Jan 11, 2018 12:10 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
Clifford B. wrote:
(quoted from post at 15:13:20 01/11/1Cool
same here, altho in my case, it required swapping out the battery. it was marginal to begin with, and that little oversight killed it.
that was in my WD, which has a toggle switch for the ignition. that's on my list of things to replace this winter. i figure i'm less likely to leave a key in the ignition than to fail to notice the position of a toggle.
tractorguy2
PostPosted: Thu Jan 11, 2018 1:21 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
Leaving the key on will sometimes ruin the points. If it has been converted to 12 volt. It can burn out the diode in the Delco alternators.
I would just charge the battery, try to start it and see what works/ doesn't work.
davidbrodhead
PostPosted: Thu Jan 11, 2018 2:56 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
I lucked out. Charged dead battery all day. Tractor instantly fired up like nothing had ever happened. I guess I have used up all my luck for 2018 !
Thanks for everybody's input.
Bruce (VA)
PostPosted: Thu Jan 11, 2018 4:01 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
Yep, you're a lucky man. If your tractor is 12v, you are a very, very lucky man. Go buy a lottery ticket!
HFJ
PostPosted: Thu Jan 11, 2018 5:02 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
mine's 12 volt as well. how lucky are we?
davidbrodhead
PostPosted: Thu Jan 11, 2018 6:55 pm    Post subject: Re: 9n ignition switch left on Reply to specific post Reply with quote
mine is a 6V system
Goto page 1, 2  Next
Page 1 of 2
