engine swap
gregjo1948
PostPosted: Fri Jan 12, 2018 6:59 am    Post subject: engine swap Reply to specific post Reply with quote
Will a Jubilee engine bolt into an 8N?
Thanks, gregjo1948
Kirk-NJ
PostPosted: Fri Jan 12, 2018 8:35 am    Post subject: Re: engine swap Reply to specific post Reply with quote
No
gregjo1948
PostPosted: Fri Jan 12, 2018 2:41 pm    Post subject: Re: engine swap Reply to specific post Reply with quote
[quote="CVPost-Kirk-NJ"](reply to post at 22:35:13 01/12/1Cool [/qu
THANKS
Kirk-NJ
PostPosted: Fri Jan 12, 2018 3:35 pm    Post subject: Re: engine swap Reply to specific post Reply with quote
What do you need an 8n engine or NAA engine? Also post your location. shipping can kill a deal
gregjo1948
PostPosted: Fri Jan 12, 2018 6:09 pm    Post subject: Re: engine swap Reply to specific post Reply with quote
I don't need either. I have a rebuildable NAA that I'd like to be rid of. A fella on CR is looking for an 8N block and I thought if my NAA could be installed into an 8N, without a lot of fabricating, I'd get rid of it. I bought two basket-case Jubilees at auction and made one nice one. I use the bellhousing to the rear of the other to fix a 2000 that had a bad "Select-o-Shift". The only thing I have left from the three tractors is one NAA engine.
THAT'S THE REST OF THE STORY! gregjo1948
gregjo1948
PostPosted: Fri Jan 12, 2018 6:15 pm    Post subject: Re: engine swap Reply to specific post Reply with quote
I think the 2000 trans. is actually a "Select-O-Speed".
gregjo1948
Kirk-NJ
PostPosted: Sat Jan 13, 2018 1:13 am    Post subject: Re: engine swap Reply to specific post Reply with quote
Ok now I understand. It will only fit from NAA and up. Later
series might also need the plate at the flywheel to also be
changed. Good luck with your sale.
Kirk
