Naa starter bendix problem
Richard riopel
PostPosted: Fri Jan 12, 2018 9:00 am    Post subject: Naa starter bendix problem Reply to specific post Reply with quote
Ford NAA- I have a problem with bendix disingaging before engine starts. My tractor has ben converted to 12v, has alternator and
electronic ign. I am not sure if the starter is 12v. As soon as the engine fires and tries to start the bendix kicks out and the starter
just spins without turning the engine. When I leave ign switch off starter will turn engine fine. What"s the problem Ive tried everything
except changing starter? Ive installed a new battery,cleaned all connections on Battery and starter.
tractorguy2
PostPosted: Fri Jan 12, 2018 9:52 am    Post subject: Re: Naa starter bendix problem Reply to specific post Reply with quote
That is the way the old style bendix works. Kicks out as soon as the engine fires. Works in warm weather. Makes starting difficult in cold weather.
You need to buy a new ratchet style drive. Won't kick out as quickly.
old
PostPosted: Fri Jan 12, 2018 10:04 am    Post subject: Re: Naa starter bendix problem Reply to specific post Reply with quote
You say you tried everything did you try adjusting the timing a bit?
Richard riopel
PostPosted: Fri Jan 12, 2018 11:44 am    Post subject: Re: Naa starter bendix problem Reply to specific post Reply with quote
Thanks for the quit response. Is the one sold at yesterdays tractor new type.
tractorguy2
PostPosted: Fri Jan 12, 2018 5:31 pm    Post subject: Re: Naa starter bendix problem Reply to specific post Reply with quote
Yes it is the new style.
