Massey 300
Goto page 1, 2  Next
pjbofmn
PostPosted: Fri Jan 26, 2018 4:59 am    Post subject: Massey 300 Reply to specific post Reply with quote
If was going but a Massey
Ferguson 300 combine what would
I be looking for problem areas?
Places to check out to see if
it's any good. It's 1000
dollars. Gas engine. I 've
never been around a combine
before.
Eric in IL
PostPosted: Fri Jan 26, 2018 8:38 am    Post subject: Re: Massey 300 Reply to specific post Reply with quote
It has been a long time since we had one, but I do remember replacing the exhaust manifold that was cracked in several places. You could almost read a newspaper at night from the reddish-orange glow of the manifold.
pjbofmn
PostPosted: Fri Jan 26, 2018 9:35 am    Post subject: Re: Massey 300 Reply to specific post Reply with quote
Lol
Young Mechanic
PostPosted: Fri Jan 26, 2018 5:07 pm    Post subject: Re: Massey 300 Reply to specific post Reply with quote
Check the basics of coarse you know, tires, runs good, leaks, welds, has it been stored inside, etc. Look at bearings if they have red paint on them they have probably not been changed. The problem most masseys have is the unloading auger tubes get wore out and rust out, then they leak grain. Be sure and look at the unloading auger tube under the hooper. Auger leaks can be fixed usually, just takes time.
504
PostPosted: Fri Jan 26, 2018 6:36 pm    Post subject: Re: Massey 300 Reply to specific post Reply with quote
That seems to be a common problem with the industrial 225s.
jwmfarms
PostPosted: Mon Jan 29, 2018 3:38 am    Post subject: Re: Massey 300 Reply to specific post Reply with quote
My father worked at a Massey and Oliver dealership from '59 to '68. They sold a lot of gas tractors and combines back then. He sold a 300 gas to the fellow that was renting our farm at the time. That combine never had anything but Amoco high test gas through it. It never ran hot, cracked a manifold, burnt a valve, or needed the muffler replaced. Those that ran regular gas kept the parts counter and shop busy with those repairs.
pjbofmn
PostPosted: Mon Jan 29, 2018 4:38 am    Post subject: Re: Massey 300 Reply to specific post Reply with quote
Yeah far as I know slant sixes are bullet proof
3020G
PostPosted: Mon Jan 29, 2018 3:51 pm    Post subject: Re: Massey 300 Reply to specific post Reply with quote
If you are who I think you are, of the area of princeton. I'm Dan's son in law you can text or call me. I work for MF dealer and I've seen several 300's.
pjbofmn
PostPosted: Mon Jan 29, 2018 6:19 pm    Post subject: Re: Massey 300 Reply to specific post Reply with quote
I don't have your info
3020G
PostPosted: Mon Jan 29, 2018 7:58 pm    Post subject: Re: Massey 300 Reply to specific post Reply with quote
765-341-0916
JMS/.MN
PostPosted: Mon Jan 29, 2018 8:34 pm    Post subject: Re: Massey 300 Reply to specific post Reply with quote
If you"ve never been around a combine before, there are way better options than to buy a Massey. Yes, they are a good machine, produce a good sample, but others are way easier to work on. Especially Gleaners, also JD 45/55/ and IH 15 series, although they have burn issues from
bursting oil hoses. Gleaner K,F,F2,M, etc....way better for a beginner.
pjbofmn
PostPosted: Tue Jan 30, 2018 8:46 am    Post subject: Re: Massey 300 Reply to specific post Reply with quote
Maybe I'll keep an eye out for gleaner and skip the 300. But the 300 was cheap and near home
3020G
PostPosted: Tue Jan 30, 2018 11:18 am    Post subject: Re: Massey 300 Reply to specific post Reply with quote
300’ s are tough little machines. They can be very reliable or junk. The gas burners run best on a 3 narrow or 2 wide head. The way I remeber is a 300 is like a 410 when it comes to headers. It could have been built two ways, with quick attach heads like a modern combine. Or where the feederhouse is part of the head. The latter being hard to find heads if you need to switch them out. Biggest thing to watch on a 300 I think is check the straw walker blocks, auger pans, auger flightig, throat chain tightness, check the cylinder shaft, also check your teeth on your gears if they are short and stubby it’s junk. You’ll spend more making it run than it’s worth if bearings are shot or sprockets. Belts I would watch, especially big flat belts. Other than that it’s just s piece of equipment. If it’s got a chopper on it I’d take it off if I was going to run corn.
pjbofmn
PostPosted: Tue Jan 30, 2018 1:20 pm    Post subject: Re: Massey 300 Reply to specific post Reply with quote
Hay thanks
pjbofmn
PostPosted: Tue Jan 30, 2018 4:11 pm    Post subject: Re: Massey 300 Reply to specific post Reply with quote
How would I know if it's quick
attach or not
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
