add drawbar hitch?
bones774
PostPosted: Fri Jan 26, 2018 8:20 am    Post subject: add drawbar hitch? Reply to specific post Reply with quote
I have the pictured setup for a belly mower. Can anyone see a way to hook up a hitch w/o removing the mower each time?
Patch700
PostPosted: Fri Jan 26, 2018 5:35 pm    Post subject: Re: add drawbar hitch? Reply to specific post Reply with quote
almost looks as though the pulley is large enough that it would
obstruct a straight bar that mounted off the bottom plate...
perhaps a bar that has an S bend and mounted to a plate that
would bolt to your existing plate that the mower uses?
Kirk-NJ
PostPosted: Sat Jan 27, 2018 12:54 am    Post subject: Re: add drawbar hitch? Reply to specific post Reply with quote
Ford made a fixed position flat plate hanger for their swinging drawbar. It's the one on the right in the diagram, hit the link. you may be able to line it up thru the pulley. Obviously you can't
use them at the same time. I have the plates off the tractor if you need measurements.
Kirk
link
Kirk-NJ
PostPosted: Sat Jan 27, 2018 12:58 am    Post subject: Re: add drawbar hitch? Reply to specific post Reply with quote
Link didn't work right. When you hit the link scroll down to hydraulic systems then click on swinging drawbar.
