Clutch pedal has no tension
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
mcglockin
PostPosted: Thu Feb 08, 2018 5:33 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Is this where y'all drive the wedge?[/img]
Hobo,NC
PostPosted: Thu Feb 08, 2018 5:45 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Yes
Royse
PostPosted: Thu Feb 08, 2018 5:56 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Pictures courtesy of John Smith - Link
Hobo,NC
PostPosted: Thu Feb 08, 2018 6:00 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
BTW this is a pix of one that the parts were so worn the clutch would not release that sounds much like yours.
mcglockin
PostPosted: Thu Feb 08, 2018 6:11 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Hobo,NC wrote:
(quoted from post at 19:00:32 02/08/1Cool
Yes they we worn pretty good. I replaced the whole assembly. But when pressing the pedal it would give a little resistance then go all the way down. Then I would have to disconnect the linkage from the pedal to reset it. Feels like something is not catching on the inside.
Hobo,NC
PostPosted: Thu Feb 08, 2018 7:09 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Got to be sum'N to that statement... I will sleep on it... Sounds like your are driving past something and have to back up to see it again
Info I think you left out till now....
Hobo,NC
PostPosted: Thu Feb 08, 2018 7:11 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
I think I would get hold of the leaver and give he a spin its got to come to a stop somewhere and no need to back'er up...
mcglockin
PostPosted: Thu Feb 08, 2018 7:23 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Hobo,NC wrote:
(quoted from post at 20:11:19 02/08/1Cool
Ill give it a shot, any specific way? Or whatever way itll turn? Do you think the clutch fork got spun around? Thanks for all the help!
Dollar Bill
PostPosted: Fri Feb 09, 2018 12:55 am    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Be sure to hammer them in fairly tight. If one should fall out, the engine could flop over to that side. That's excitement that nobody wants.
mcglockin
PostPosted: Fri Feb 09, 2018 2:10 am    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Ok thank you!
Hobo,NC
PostPosted: Fri Feb 09, 2018 4:25 am    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
mcglockin wrote:
(quoted from post at 09:23:52 02/09/1Cool
I would think in it original direction of travel its not gonna fix it but prove what you may find once to get into it....
Royse
PostPosted: Fri Feb 09, 2018 8:21 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Apologies, I posted this in the wrong place.
Hobo,NC
PostPosted: Sat Feb 10, 2018 10:25 am    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
Been thinking about your "reset statement" I am not sure what you mean by dat. Take the floor board (FB) off the FB is the pedal stop it would be interesting to see how it works from there...
All in and done with the fix the FB needs to put back on to adjust and check normal operation Wink
Royse
PostPosted: Fri Feb 16, 2018 4:58 pm    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
mcglockin, did you figure out what was wrong with your clutch?
I took this roll pin out of an 8N. It reminded me of your post.
Dollar Bill
PostPosted: Wed Feb 21, 2018 1:21 am    Post subject: Re: Clutch pedal has no tension Reply to specific post Reply with quote
What Royce said - Inquiring minds want to know.
Page 4 of 7
