Probably a dumb question
jerkus730
PostPosted: Sun Jan 28, 2018 7:18 pm    Post subject: Probably a dumb question Reply to specific post Reply with quote
Is it possible to pull the transmission out of a WD without pulling the engine?
DrAllis
PostPosted: Sun Jan 28, 2018 8:14 pm    Post subject: Re: Probably a dumb question Reply to specific post Reply with quote
The transmission is in the rear end housing which starts underneath the battery box. So, no..... removal of the engine isn't required.
JMS/.MN
PostPosted: Sun Jan 28, 2018 9:24 pm    Post subject: Re: Probably a dumb question Reply to specific post Reply with quote
Yes. The I&T AC 11 service manual has an illustration of using long line-up bolts when separating the frame from the rear axle, giving you access to the transmission. Personally, I"d prefer to move everything forward, and maintain stability of the tractor.
Moonlite37
PostPosted: Sat Feb 03, 2018 9:41 am    Post subject: Re: Probably a dumb question Reply to specific post Reply with quote
It is possible, but removing the engine is so easy, I could see no reason not to pull the engine
DrAllis
PostPosted: Sat Feb 03, 2018 11:40 am    Post subject: Re: Probably a dumb question Reply to specific post Reply with quote
Please explain to me WHY you'd want to pull the engine to work on the transmission on a WD...?? There is absolutely nothing to gain by doing that....nothing. The 4-speed transmission is in the rear end housing, about 3 feet behind the engine.
