MW o-rings sleeves
DoubleBFarms
PostPosted: Fri Feb 02, 2018 6:44 pm    Post subject: MW o-rings sleeves Reply to specific post Reply with quote
I have a allis chalmers d-17 gas with M&W pistons, Trying to find o-rings to fit M&W sleeves.
JMS/.MN
PostPosted: Fri Feb 02, 2018 7:10 pm    Post subject: Re: MW o-rings sleeves Reply to specific post Reply with quote
Did you check a Hastings catalog?
DrAllis
PostPosted: Fri Feb 02, 2018 7:32 pm    Post subject: Re: MW o-rings sleeves Reply to specific post Reply with quote
Good luck if you can find them !!! I'll take a set of eight if you do. They are an odd size and I don't think you'll find any of them anywhere. I hope I'm wrong.
Aaron SEIA
PostPosted: Sat Feb 03, 2018 5:13 am    Post subject: Re: MW o-rings sleeves Reply to specific post Reply with quote
Might be more work, but why can't you drop the M&W pistons in a stock AC or aftermarket sleeve? I understand if you have good sleeves you want to reuse.
AaronSEIA
EP
PostPosted: Sat Feb 03, 2018 5:32 am    Post subject: Re: MW o-rings sleeves Reply to specific post Reply with quote
Try McMaster Carr
Mike(NEOhio)
PostPosted: Sat Feb 03, 2018 6:04 am    Post subject: Re: MW o-rings sleeves Reply to specific post Reply with quote
I have a set of six that I ordered from Reliance. Wrong ones due to the usual Allis-Buda mixup. Got the right ones and they didn't want them back. If you think they'll work.
Brian G. NY
PostPosted: Sat Feb 03, 2018 7:29 am    Post subject: Re: MW o-rings sleeves Reply to specific post Reply with quote
Try this place: Global O-Ring and Seal, LLC.
Great people to deal with.
A few years ago I picked up a log splitter that had a leaky ram .
I took it apart and found what seemed like a really wide groove for an O-ring. Turns out the prior owner had had it apart and removed a "backing ring" that went in the groove along with the O-ring.
I had never heard of such a thing! Now, I know you don't need a backing ring but the point is, this outfit helped me figure out exactly what I needed to fix the problem.
If you go to this site, I'm sure you will be able to get the O-rings you need for your sleeves.
They have groove measurement charts and they can fix you up with any size imaginable.
They also explain what composition O-rings fit what application.
I never knew there was so much to know about O-rings.
I use it for a reference source now.
BushogPapa
PostPosted: Sat Feb 03, 2018 9:46 am    Post subject: Re: MW o-rings sleeves Reply to specific post Reply with quote
When installing, use Permatex #2 non-hardeniing sealer on those O-rings and plenty enough to coat the web between the sleeves..
Allis Dave
PostPosted: Mon Feb 05, 2018 12:44 pm    Post subject: Re: MW o-rings sleeves Reply to specific post Reply with quote
At one point I think Norm Meinert said he could get them.
It might be worth a try.
www.normstoys.com
