Sickle mower horsepower
Goto page 1, 2  Next
SVcummins
PostPosted: Mon Feb 05, 2018 8:56 pm    Post subject: Sickle mower horsepower Reply to specific post Reply with quote
What horsepower does it take to run a sickle mower will this pto shaft run it ?
https://www.agrisupply.com/pto-shaft-series-1-6-spline/p/102265/?sid=asf10&eid=Easf10&utm_source=GoogleShopping&utm_medium=CSE&utm_campaign=MerchAdv&zmam=77232640&zmas=1&zmac=1&zmap=102265&utm_source=google-shopping&utm_medium=cpc&utm_campaign=NB_PLA_PTOShaftsAccessoriess_NW_GOOG&utm_term=shopping&utm_content=s9HlirsSd_dtpcrid194324646884pkwpmtproduct102265&gclid=EAIaIQobChMIt-n4h72Q2QIVSGB-Ch0M5gqHEAQYASABEgJr9_D_BwE
Bob
PostPosted: Mon Feb 05, 2018 9:19 pm    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
Your DEERE #8 mower originally used a "6 series" driveshaft.
That driveline series is rated between 12 and 16 HP @ 540 RPM;s, depending upon which source you choose to rely on.
SVcummins
PostPosted: Mon Feb 05, 2018 9:29 pm    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
The oem Deere is rated at 12 to 16?
DeltaRed
PostPosted: Mon Feb 05, 2018 9:35 pm    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
Not really sure what you are asking...but we used to run a jd #5 on a Farmall H in high altitude grass hay in 8000' Gunnison Co.The old worn out H had no problem with the heavy tough hay.
SVcummins
PostPosted: Mon Feb 05, 2018 9:40 pm    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
How many hp are they
SVcummins
PostPosted: Mon Feb 05, 2018 10:10 pm    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
I need to make a longer pto shaft and agri supply has some but I need to know about how much horsepower it will take to run the mower so I get a shaft that?s heavy enough
Graham of New Zealand
PostPosted: Tue Feb 06, 2018 2:08 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
On a different note, two horsepower used to pull a mower and drive a 4' 6" sickle cutter bar. (But needed a rest and a drink now and then)
Traditional Farmer
PostPosted: Tue Feb 06, 2018 3:06 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
I pull a 7ft New Holland trailer sickle bar mower with a 31 HP Yanmar if that helps.
KL in Wi
PostPosted: Tue Feb 06, 2018 5:02 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
I cut many acres of hay with an 8N Ford and a 7ft NH mower. It had plenty power.
hydro70guy
PostPosted: Tue Feb 06, 2018 5:06 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
I cannot imagine a PTO shaft built to light to run a sickle mower. That does not make sense to me the only way it takes much HP at all is if its very dull and extra long.
Joe
showcrop
PostPosted: Tue Feb 06, 2018 5:07 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
A friend used to pull a 5 footer with his 2 cylinder 17HP Kubota, no problem at all.
rufus80
PostPosted: Tue Feb 06, 2018 7:39 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
We used ,continue to use, our 52 MT with a jd no5 7' mower. It handles just fine for the past 66 years. Also used to pull a NH 479 mower conditioner with our 52 A.
Leroy
PostPosted: Tue Feb 06, 2018 8:23 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
They still do 7' but 6' is prefered. About had to go to a 1 horse to get that small of bar.
Bob
PostPosted: Tue Feb 06, 2018 9:32 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 00:29:11 02/06/1Cool The oem Deere is rated at 12 to 16?
Yes.
That's what I said.
Parts catalog lists the U-joint cross kit as # AE793E, which is a kit for a 6R series driveline.
MtMan
PostPosted: Tue Feb 06, 2018 9:52 am    Post subject: Re: Sickle mower horsepower Reply to specific post Reply with quote
Well years ago when I was a kid on the home farm I mowed with a sickle bar mower with 2 horse power. There names were Flori and Tony. Just kidding you all but that's what I used.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
