1985 1910 4wd tractor 3 pt hitch
mcc2
PostPosted: Thu Feb 08, 2018 7:56 am    Post subject: 1985 1910 4wd tractor 3 pt hitch Reply to specific post Reply with quote
Hi all I need to the forum and hope you will be able to help me.I purchased in 1985 Ford 1910 tractor with the backhoe on it. It has 800 hours on it. The backhoe has been on the tractor since it was new. The brackets that hold the backhoe onto the tractor were bolted and welded. I had the tractor worked on so I can remove the backup. My next challenge is to set it up with a three point hitch it seems that it is going to be hard to find parts for it can anybody give me suggestions as to where I can find parts for the three-point hitch. I need everything. Thanks for your help will.
Sean in PA
PostPosted: Thu Feb 08, 2018 8:19 am    Post subject: Re: 1985 1910 4wd tractor 3 pt hitch Reply to specific post Reply with quote
I think your only chance is to find a salvage yard that has one to get the parts from.
JoeM(GA)
PostPosted: Thu Feb 08, 2018 6:47 pm    Post subject: Re: 1985 1910 4wd tractor 3 pt hitch Reply to specific post Reply with quote
here's another I just ran across -
Hoye Tractor Co
Sean in PA
PostPosted: Fri Feb 09, 2018 6:15 am    Post subject: Re: 1985 1910 4wd tractor 3 pt hitch Reply to specific post Reply with quote
CVPost-JoeM(GA) wrote:
(quoted from post at 22:47:06 02/08/1Cool here's another I just ran across -
Hoye Tractor Co
That is just a generic external kit for the arms and linkage.
I don't know exactly what the OP's tractor has on it now, but he said "I need everything", so if the tractor truly does not have a 3 point lift then that will not give him a working 3 point system. He will need the hydraulic top cover hat has the lift cylinder, touch control handle and control valve, etc. If it has the hydraulic top cover and is only missing the external arms, then yes, that kit would work.
CJinMI
PostPosted: Fri Feb 09, 2018 1:10 pm    Post subject: Re: 1985 1910 4wd tractor 3 pt hitch Reply to specific post Reply with quote
Busted one for sale.
Tractor Talk, part way down,
titled ooooo,killer deal.
(don't know where you're at).
Craigslist,ebay, Weavers compact tractor parts, West Kentucky tractor parts, 1 I don't remember.
